Welcome all suggestions on the Douk Audio DAC-Q11--We are going to design its updated version!!!
1st,...
2nd,...
3rd,...
4th, it looks nice, has a glowing window, a huge knob, and a remote. These are all worthy benefits for $160....worth a lot more to most home users than balanced outputs which many pixel peepers here happily pay for.
5th, I would have paid +$40, if it had come with balanced outputs but NOT for testing purposes: I have a current use case, where Q11 feeds two different locations.;)
Having an issue with the Q11. As I'm playing various music from Amazon Music, the bit rate will change from 192khz (or 384 if thats what i set) to 352khz on the Display, and the sound will sound very tinny, and muffled. I then have to cycle through the optical, and coax, to get back to USB, to fix the issue. I'm usually in AKM mode, have yet to test if this issue is repeatable in the ESS mode. I have tried 2 units to and am experiencing the same bug.
I could be wrong, but it seems like its almost like some kind of protection kicking in.
It could be my pc, however the SMSL-SU1 doesn't do that, and neither did the Aiyima DAC-A2. I also recently (2 days) did a fresh reformat of windows 11 pro.
Almost certainly a driver issue.
Can you update drivers - or change them completely - eg to ASIO.
I installed the drivers that Douk recommended. Pretty sure they were called Saavi Audio. I'lll google around for the ASIO you recommend. Are those universal drivers?
Superb! This kills the curiosity of having two DACs to find out which is better. DACs may sound all the same but for one who wants to know this answers it. Same implementation I guess. Congratulations Douk Audio. Ignore the nasty comments.
There we have it, it's the "Ampapa Q1" by Douk Audio, the betoken successor of their "Q11" dual DAC chipset model. https://doukaudio.com/products/ampapa-q1
...And the foreseeable direct competitor to the upcoming "D20" DAC by Aiyima with -likely- comparable specs.
To begin with, I find it a little disappointing that when it comes to Bluetooth audio codecs support - no progress has been made. Still no aptX Adaptive support, just as not even well-established LDAC implemented.
The looks is quite sleek.
Once again, as it was the case with the Q11, I like the dual output section - a whole lot of opportunities for tinkering with two amplifier-speaker|headphone setups connected. With TRS added, it's actually quadruple output now.
Без поддержки аудиокодеков Bluetooth aptX Adaptive и LDAC - просто обычный ЦАП. Для приема Bluetooth, как и для передачи придется покупать другое устройство. Тогда зачем тут сделали Bluetooth ? - увеличить цену для не понимающих людей ? Странное решение - для тех кто не понимает и не слышит есть более дешевые и универсальные устройства. Бог с ним, с aptX Adaptive , но LDAC - то почему нет ?
"Это фиаско, братан". Какая-то тупиковая модель получилась. Разочарован. Пока оставлю своё древнее fiio , которое кстати почти все на том-же процессоре es9038 q2m.
Сравнения ess es9038 q2m vs 9039 q2m, по звучанию - для конструкторов, 9039 несомненно большой шаг, так как в не сильно навороченных конструкциях позволяет упростить и удешевить схему (не нужен микроконтроллер).
Если не для измерительных целей, а для "слушать", не обращая внимания на циферки у Амира, то пока никто реальных отличий в их звуке не услышал. Конечно, наверняка найдутся и те кто услышат.
Подождем, что конкуренты предложат.
Please update you USB port on all device with DACs to type C for better connectivity. Will definitely buy one if it changes.
How's that going to change the connectivity, other than using a C-C cable rather than a C-B cable or an adapter?
I'm guessing, that like me @R3adyHor1zon would like to standardise all his gear on type C connections to avoid the plethora of cables needed. It would be most convenient to know that whatever cable I pull out of the cable bag has the ends on it I need to use with the devices I am trying to connect.
Yes mate, ur 100% correct. I simply don't see any reasons for using those outdated USB B port. It's an absolute waste for having a USB A/C to B cable which cannot be used in any other devices which are commonly used nowadays. Someone may argue that this cable will be forever connected to the DAC, but I don't think this "not so serious" type of products need to be connected all the time on your desktop when there are a bunch of other devices using Type C. And yes, if it's type C, I can plug whichever extra new-gen iPhone cable, or gaming controller cable to it.
That's a mixed blessing - is the cable you just pulled out rated for the speed you need? Power only, or power and data? The 80Gbps cables are a lot more expensive too, so there's a penalty for just making sure they're all fast.
On the other side at least PD won't kill your device like the wrong PSU can with a barrel jack. Especially when one manufacturer decides to use the same barrel jack on models of thin client that take 5V, 12V and 19V, and not include protection in case someone isn't checking carefully which is which...
If you really want to use a USB-C cable you can get a PD barrel jack adapter for the necessary voltage. You still need to make sure your PD charger can actually supply that voltage, or you'll be wondering why it doesn't work.
Reactions: MCH
for a similar cost, one could make a four-channel DAC
And both the 6-channel and 8-channel versions for slightly more :D .
For speed, it's absolute nonsense. Almost all music files could be transferred quickly enough even through a USB 2.0 port, which is generally used on these outdated USB B port. I would say it's actually a cost saving solution for most companies using B port. Additionally, an 80Gbps cable doesn't boost your transfer speed any faster on the port limiting the speed. Even think about using Thunderbolt port, the maximum speed is 40Gbps and I don't see any point of the 80Gbps example.
For safety, you are definitely saying the opposite thing. The old type C cable would have the problems you said, but with current standardized type C cable and PD cable design, nothing will burn your electronics. Also, if someone has a PD cable, I will assume it is used for power all the time. Even they use it for data transfer, it's totally fine.
Despite these, it doesn't seem to be any decent excuse for not standardizing the USB port or using USB B exclusively for music data. Type C nowadays is commonly seen on many external sound card, equalizers, or pro DAC and compact size devices.
It makes no difference for this 480kbps product, but for @antcollinet's comment about every cable you pull out of the bag just working it is an issue if you have faster devices. 80Gbps is Thunderbolt 5.
Apparently I wasn't clear - it's the barrel jack that has a real problem frying things unless the manufacturer includes overvoltage protection. This is an area where PD has an advantage, although there can be confusion when the PSU doesn't support the voltage the device needs as most people don't look at that sort of spec detail.
Not what I said. I said every cable having the right ends on. If they do, then 99 times out of a hundred (or more) they'll just work. 80Gb/s is an edge case.
