www.audiosciencereview.com
I object on the ground it promotes audiophile mythology and misinformation. I particularly object to that being promoted here.
I personally think it's a great idea, as people can do blind A/B's of the equipment (assuming the output is the same volume when you switch between the chips. I would actually like a convenient way to switch between chips (even better if I could plug my own in) so that I could determine through blind testing if I could hear a difference, and if so which I preferred.To enjoy different sound styles of two top DAC chips via only one DAC?
What do you think of this switchable design? Let's discuss Douk Audio DAC-Q11 together!
The only way to really tell if it's utter nonsense is to A/B test. This facilitates that. So wouldn't we be supportive of this as it gives the convenient ability to perform the only truly valid testing of whether the op amps sound different?For me - sorry to say - utter nonsense.
We don't want sound effects. We want accurate reproduciton. Both chips are capable of doing that. Pick one - use it and do the design right.
I realise this doesn't help with gimmick marketing. How about, instead, offering features of genuine benefit to the customer. Balanced connections, usable display etc etc. Best of all, you could spend the money from the second DAC chip on some DSP, and implement decent built in room correction.
I often turn down my volume when deciding between 6 and 7 on my preamp based on the particular track. But yes the important point here is the device would ideally match volumes for output.The one with the higher output voltage will always be preferred. What a waste of time.
No, but because (as stated in my other posts) - the aim of Hifi is accuracy, and:The reason I assume you are against is that you've concluded there is no difference and so this will only either establish what you believe you already know to be the case, or that it will be used incorrectly to foster an incorrect conclusion. I'd rather be given the option to make that decision myself without your biases,
If you've done the design right, there shouldn't be an audible difference to enable subjective sound/preference - other than bias effects. If you've done the design poorly enough to result in an audble difference, don't expect those of us who value high fidelity to be interested.
If they sound different, then at least one of them is not accurate.
I object on the ground it promotes audiophile mythology and misinformation. I particularly object to that being promoted here. There is too much of that in the world already (regardless of price).
I appreciate engaging with the community on product designs, however at ASR it's generally believed that two good DAC chips should have no "sound" of their own at all. So perhaps this forum is not the best audience to get feedback on this concept.
But only if it were possible to balance the output levels - because they are not by default.Cause that would be interesting.
The product is already designed, tested and on pre-order... I don't think they're after feedback on the concept.
JSmith
If recognized by PC it should be easy through windows mixer or MP or so.But only if it were possible to balance the output levels - because they are not by default.
