Weiss DAC205 DAC Review
Rate this DAC:
    Votes: 119 49.2%
    Votes: 100 41.3%
    Votes: 15 6.2%
    Votes: 8 3.3%
Weiss was very relevant 10 to 30 years ago, and pricing was always very high (but the quality then also). But it seems they did not move on or this is an older unit. Today that price is not worth it anymore, i agree. RME is better for pro audio, and for hifi there are many way cheaper options that beat that with ease.
BTW they both use the ES9018S chip.
If so, they are extracting pretty good performance out of that DAC, the issues I found notwithstanding.
seem to be current items?
What a pleasure to see that money don't make (musical) happiness.
Yes it seems like.
https://weiss.ch/products/highend-hifi/dac205/
ps. considering ess9018 chip it's a very good device that is competently designed. The only puzzle is multitone - but I assume it will change drastically with tones that are not full scale.
Ha! Love this Steve Huff Guy. Wonder what type of oil he uses for his mustache
He says : This DAC has a clarity and crispness that I have never heard in this price range.
Tru dat. You gotta go down to $200 range to get that level of clarity these days.
I think the appropriate rating for this DAC would be no panther as it is mostly irrelevant today outside of the realm of engineering curiosity.
I imagine that you are putting things into perspective given the age of this ESS chip)
This review doesn't prove that. Thousands of people spend inordinate amounts of money on audio stuff, and seem to be perfectly happy doing that :oops:
Just to offer some general insight.
Weiss has a lot of pedigree in the pro world (and therefore amazing customer support). Many professionals buy their products, only because it’s a proven industry standard.
RME, UA, Benchmark, Lynx, etc also are proven, industry standard manufacturers with pro level support, and their products generally perform much better so there isn’t really an excuse to go with Weiss over the former.
However, it is not fair to compare products like this with consumer level gear like Topping, SMSL, etc…. as, proven track record of reliability, flawless driver development, and ultra-short turnaround support infrastructure outweigh bleeding edge technical performance in professional settings.
I’ve said this quote before but I’ll say it again:
Problematic gear for enthusiasts (like most on this forum) costs them inconvenience.
Problematic gear for professionals can cost them tens of thousands of dollars of downtime and loss of clients and a severely damaged reputation.
$2,600 (?) for something that should have cost $100 max provided it was well constructed, but clearly it isn't.
This is a review and detailed measurements of the Weiss DAC205. It was kindly sent to me and appears to be recently discontinued. Original price (I think) was around $2,600.
While the case looks pretty basic, it is fine with me. Sure, for that kind of money, you would want it to have an OLED display with every feature imaginable but you are not going to get that. Nor will you be able to connect using USB as the only inputs are Toslink and Coax. Back side shows the typical connections:
Again, for this price I expect to see built-in power supply but an external switcher is provided.
The two switches provide different levels of output although none are compliant with our standard as you see below in measurements.
Weiss DAC205 XLR Measurements
The closest I could get to 4 volt was 2.4 volts:
This is quite competent performance although very shy of state of the art:
Setting output to max gain and sweeping input we get:
Noise performance is excellent:
IMD distortion shows mid-level increase which tends to imply less than ideal implement of ESS (?) DAC:
Linearity is excellent:
My standard multitone test runs at 192 kHz which I can't use over Toslink so ran a 44.1 kHz version:
Your guess is as good as mine as to why we have such high levels of intermodulation distortion. I checked against a Topping D70s by moving the cables and running the same identical test and none of that was there. So clearly this is a problem with the unit (same happened over coax).
Jitter performance is another head scratcher:
But then single tone 50 Hz performance is superb:
We see the typical DAC IC filter:
THD+N vs frequency is very good:
The performance of DAC205 is excellent in a number of tests but there are some really odd results in a couple of tests. Company speaks highly of their jitter reduction but we are seeing the worst jitter I have ever measured in a performant DAC. The multitone test results is a real puzzle. Even if the performance was good, we would need USB support and pricing below $500 even if the unit is made in Switzerland. High-end products that garner such high list price come with vary fancy casework and pride of ownership. None of that is here. Folks are supposed to buy on reputation but test results indicate that is not wise.
I can't recommend the Weiss DAC205 even if it were still being sold. I see used ones as high as $2,000. No justification for that.
This gives the impression that it's a current product <https://weiss.ch/products/highend-hifi/dac205/#information> and that it's "pro quality". Whatever is the case, the performance and features do not justify such a high price. Perhaps a lot of money was wasted on 4 converters per channel, and wouldn't a "pro" device have Chord-level filtering?
I shared weeks ago the Measurements of the DAC204, they are almost the same :
The WEISS DAC205 offers the same conversion quality but it does not accept digital audio via USB and does not perform DSD to PCM conversion.
We are therefore OK to say that it does not live up to its price) and that the DAC205 does not provide anything more than the DAC204. BTW they both use the ES9018S chip.
DAC204
The Weiss website says it used 4 converters per channel. Does that mean 8x 9018 in total?
