IPunchCholla
- Joined
- Jan 15, 2022
- Messages
- 1,437
- Likes
- 2,002
I’ve been running into a weird ground loop issue and was hoping someone might be able to help find a solution.
Equipment: (connections in parenthesis)
Technics SL-QD33 connects to Cambridge Audio Alva Solo (ground and rca) connects to Focusrite Scarlet 4i4 (long RCA with RCA to TRS adapters) connects to Mac Mini M1 (USB-C).
Output is Mac mini to 4i4 to Presones Eris 66s (via TRS).
All equipment is plugged into same circuit.
Symptoms:
After playing a record and only after playing a record, I get ground loop buzzing, but very faintly. The buzzing gets much louder after turning off the phone preamp. The buzzing will persist after disconnecting all incoming and outgoing connections (except usb) from the 4i4. Buzzing will get much quieter if the phono pre is turned on and connected.
The buzzing can be stopped entirely by unplugging the usb from the Scarlett 4i4. It returns once playing a record.
Things I’ve tried:
Using an adapter to remove the ground on the phono pre.
Plugging the 4i4 into ports on hubs vs ports on mini.
Resoldering the grounding wire on the turntable.
Cleaning the TT grounding wire connection at the phono pre end.
Plugging everything in to a single power strip.
Any ideas on how to resolve? Thanks!
Symptoms:
Things I’ve tried:
