Hello everybody.
I have a really weird issue. I recently bought the soundblasterx g6. I have connected it to my pc via the usb. On the sound card I have both my speakers (edifier r1700bt, back port of the sound card) and my headphones (pioneer hdj1500) connected. When both of the devices are connected, I have a pop sounds from switch on/off lights and this weird sound (this sound happens when i hold my headphones or if i hold the headphone cable near the 3.5 jack. It also happens much louder when i power the usb card via usb charger (and this is when i recorded the sound)), and also when i change from headphones to speakers and vise versa a high pinch sound that last a sec or so. IF I disconnect headphones, no issues. I have also tried a different usb cable, different usb port, to connect my sound card via optical and give power to it from a usb power bank (which the louder sound happened).
I tried the same thing with my laptop. No issues at all. Tried both with and without charger. My laptop uses a 3pin charger, which from a video I saw it might be a cause for ground loop (and in the video he suggests to use a 2 pin charger). I guess if the problem was from a poorly grounded outlet or if the issue weas from the card, I should have the same issue with my laptop too.
I changed the psu cable of my pc and the power hub, issue still there. If I dont have the headphones connected on the card, no issue. But i want to leave them connected and control the output via the software (so i can hide the sound card at desk).
I ended ordering these. Do you think it will do smth? Where should I use them? Eg should I put 1 on the usb cable, near the sound card or the other end which connects to the pc? Should i put one too on the speaker and headphone cables?
