Weber Wire Speaker Cable
Hi, does anyone know who designed Weber Wire Speaker Cable? It was a Threshold product from some time ago.
WeberWire specs*:
Cable Architecture: Ribbon configuration equivalent to 4 gauge
Inductance less than 0.024 uHenry/ft
Resistance: 0.00053 Ohm per foot
Current Capacity: 100 amps rms, 500 amp peak current
Capacitance: 0.02 nanoFarads/ft
Signal transmission: DC to beyond 5 megaHertz
*Information excerpted from Threshold WeberWire publication. WeberWorks, Inc., Threshold Corporation
Thanks for your time.
Does it make any particular difference to other and likely more cost-effective solutions? :) Never heard of them but I don't follow silly cables otoh.
Speaker cables don't need to be "designed". It's just wire.
I'm intrigued nonetheless. 4AWG? That's ~20mm²? Sounds almost like something I'd do just for the hilarity. But it better be thick, round, regular multistrand wire. If I'm gonna use cable that thick, it better look properly industrial. Not gonna deal with some ridiculous ribbon configuration.
Double that for 20mm². That's the real price of 4 AWG copper wire per meter. Not tens of thousands. Roflcopter!
Buy it, strip it, zip it, plug it, pull it, push it, double-weave it. Technologic
One would think that at over $125 grand for engineered cables from MIT, Transparent, maybe even Nordost, they have some scientific expertise. Those are out of my means, but people and studios are buying and using them -- Auditioned some Oracles at one point way back when: Went back to Goertz (Alpha-Core Magnetics) because the Oracles were out of my means. Thanks again for your time.
One would think that at over $125 grand for some MIT or Transparent cables, they have some engineering expertise. Those are out of my means, but people and studios are buying and using them. I usually just listen to how accurate cables sound and if the music makes realistic sense. Thanks for your time.
Sounds insane that you "listen to how accurate cables sound" in the first place. I think you're in the wrong forum. Music making sense depends on the music, not the wire. LOL
If you don't mind attending to context: "How accurate in context of the music making sense." Thanks in any event. Take care.
I met a vendor at Axpona of the name Matthew Bond (/https://matthewbondaudio.com/) who said he designed it long ago for Weber/Threshold.
I have some, mine is silver plated, did not have the wire spacers at the ends. I terminated them myself.
Well, he's certainly no James Bond, but he does sell a CD for burning in your cables, so he knows a thing or two about espionage.
Oh, and it's version 2.0, because version 1.0 left too many cables slightly undercooked. Several audiophiles suffered from Listhearia infections as a result. It was a real public health problem.
