Waveguide 3d Plac for Scan Speak D3004/662000 or D3004/6600 anyone?
DrSpan
Hello there.
I am looking for a Waguide 3d design that has been proven and measured in real life for the scan speak 25mm Tweeter.
It has this „special“ front plate so it needs a customized design i think
Only one i have found is Somasonus but it is a tad too big. I would ideally find one that is 4inches in overall diameter or 104mm
Does anyone here has ever done this? Or do you have any tip as to where i can find something?
Looks like the first version is 4in
Hi there.
I have looked at the Somasonus. Unfortunately even though it is called 4 inch in real life the design is resulting in 121mm which would be 4,76 inches.
4 inch is around 10+ cm.
I am looking for a waveguide that is only marginally bigger (1mm) in diameter than the original plate which is 103.5mm
Seams to be the same type of adaptor needed for Peerless XT25GB60 and XT25TG30
If you take some dimensions, we can check it and create a custom design for it
