I hope that it is OK to put one on here that I aspire to own:
NIWA Nixie watch V 2.0 - Titanium Purple Custom Burned
Features:
- Wireless charging, QI standard
- Carbon fiber back cover
- Reduced power consumption hours in standby mode.
- Work up to 100 days in standby mode.
- Disable side lamps with a battery charge less then 10%
- Disable display of all the tubes at a charge of 3% for the long-term preservation of the operation of the calculation of time.
- Disconnection of the entire system from the battery at a critically low charge to prevent degradation of the battery (time goes to 00:00)
- When the board is completely disconnected from the battery, for about a month the battery keeps a safe charge level until the internal controller of the battery triggers. The entire process from full charge to triggering the internal battery controller can take 5 months.
- Fixed showing seconds (for display does not need accurate holding the position of the hand)
- Sleep mode to save battery charge (blocking the time display in any tilt position).
Specs:
Titanium custom burned purple case
IN-16 tubes, IV-15 side tubes
Sapphire glass
Comes with leather-silicone strap
Splash water resistance
Battery lasts for up to 3 month without charging
Charging takes 3 hours
Diametr-50 mm
Hight-17 mm
