Yes. You can use
this driver and profit from LDAC, APTX HD and APTX Low latency on Windows with Bluetooth decides like the qudelix and Fiio's BTRs (AFAIK windows defaults to sbc or aac). The latency for LDAC and APTX LL is low but may not be low enough for your comp needs:
aptX Low Latency provides low-latency (~50ms) audio (compared to 150~200ms latency with other CODECs), which is good for gaming and other time-sensitive applications
Ok, yeah, that's way to much, even for casually playing. Half of a second is crazy.
An IEM could be an option instead of more expensive over-ear headphones.
I don't get warm with IEM. They just do not give me the soundstage and location I need. At least the ones that I tested from some of my teammates. Same for closed headphones. It is like everything is near me and in my head, that's so disturbing for gaming. You cant really tell where the enemy is, despite the horizontall axis.
Still I'm going to order the Truthear Gate as they are nearest to my prefered soundprofile I think
In regards to the Qudelix 5k: This isn't an option too. I'm playing competitive and this would raise the lag to a level which isn't bearable for me. Bit I've already the Fiio K11 ordered and in use
First of all, careful with the high shelf on band 5 (3000khz), Oratory usually use default Q values for it, but in this instance he did not. To properly add the 0.35 Q value, you will have to select High Shelf by Q factor on Peace. It's lower down the list than the standard high shelf you've used, which defaults to a Q of 0.7.
Second, disregard GPT final answer , it's better to learn EQ yourself or to use the guidelines from Oratory. Don't change their Q values, just the gain.
If you want more bass, increase the value of the 105Hz band to something like 8 or 9 and decrease the preamp (slider on top) to - 8 or - 9 dB so the signal doesn't clip.
For more vocal presence and details, add more gain to the 3000khz band. If the sound becomes too clinky and sparkly, compensate by turning down the 10khz band accordingly.
If you need more changes, I recommend playing around with new filters rather than further changing Oratory's. You can add more bars to Peace with the + button on the right side. For more midbass, a 180Hz band with default 1.4 Q will work, making things more thumpy. For more vocals, another 3000khz band with default Q will also work. For more treble, you can try increasing Oratory's 6000khz band.
Finally, you can more or less predict the changes you make on the squig link below by switching to the EQ tab, which uses the same rig that Oratory used to measure the HD 490 and estimates the overall change. I've added the oratory profile already. If didn't apply, just import the file I've annexed here. You can export the end result you made to peace using the export button.
Man, thanks! These are some great ressources! I've watched the whole youtube playlist and some other guides too now. This whole EQ thing is really great, I do think I understand it a bit more now.
What's contradictory: They guy says you can tune your headphone into any another headphone with EQ. Basically the opposite says another guy from yt that this is physically not possible.
AutoEQ was ok'ish - maybe because I didn't know which target curve I should use. Tried Harman OE2018 and Tilted Diffuse Field. My personal ranking of this was: Tilted Diffuse Field (But with elevated bass) > oratory eq > harman oe2018.
BUT I've tried to do my own profile, I really like it so far! Outcome:
EQ Profile with oratory1990:
My custome EQ profile based on oratory1990's:
Added my custom profile as download, if someone is interested in it.
Unfortunately I needed to put the FiioK11 from Medium to High gain - don't know why, but wasn't getting loud enough otherwise. When I finally get some balanced cable I think I can switch back again to Medium or perhaps Low?!
Haven't tested only for some minutes in gam*ing so far, just with alot of music (Cause tuning while gaming is nearly impossible, you cannot "repeat" things etc.).
If you have any recommendations or would say that something of this EQ is really off and I should change it because I'm used to bad sounding/listening or something, please go ahead!! I'm used to my Klipsch Reference Premiere 8000F II, C404 II and RP600M II.
I didn't know if I need to correct the volatile lines above 7k, so much spikes. As oratory didn't do it, I will just follow with it. But my OCD says I need to bring it parallel to the Harman Target?
Summary: it's not as "warm" in comparison to the oratory profile, I've more vocal presence, sometimes a bit of body what the oratory profile have had is missing. It's not bad, because I get the vocal presence and forwardness with it. Furthermore in movie-trailers, you can really hear the clinky sounds of weapons, f.e. when the slide of a weapon gets pulled. Or if someones jumps through glass, it's like the glass is flying right in your head
Hans Zimmer - "Why So Serious?" => Loving the deep frequencies at 3:25 and overall all the separation of the instruments, just feels great.
Billie Eilish - "Bad Guy" => punchy kick withouth boomyness.
Ben Howard - "Keep Your Head Up" => was a bit dull with oratory, but had more body. now it isn't dull anymore, bit of body is missing, but vocal presence is freaking great.
Adele - "Hello" => Vocals forward! not far away not to narrow <3
Norah Jones - "Don’t Know Why" => Ok, to be honest, the only one where sometimes the voice get a bit shrill / high. It's like a little wakeup call in my head - I don't think I could listen to something like this the whole time or at least I need to put the soundlevel down. Otherwise this sounds just great. But even with oratory profile it is similiar, bot not as emphasized with mine.
Daft Punk -"Giorgio by Moroder" => Lot of details in the depth. Especially the intro gives a great separation and a sense of space. I feel some airiness here but not too much, which feels great. Also the "pew pew lasergunz" sounds at 8:00 feeling great
I'm open for any tips and improvements!!
@Curupira Based on this, what would be the correct/audiophile description of my sounprofile? Is this something like neutral or linear or lively or just BAD and WEIRD listening habits?
I think that this profile will also suit for competitive FPS, it has good separation, location of enemies, footsteps, weapons reloading, etc.
In my opinion, a finetuning of this for FPS could be like: Everything beginning with the higher mids could get more +db. Perhaps the 10.000 HZ filter could be lifted a little bit more for this or beginning directly with the 1300HZ Band. Nevertheless the bass should get reduced for better separation in games.
