Curupira
Will you use the PEQ and built-in features of the DX5? If not, I think the dx3 is a better deal. Sure, the dx5 has leaps of power, but you'll only use that with headphones like the aforementioned HE6SE.Ok, then I will do it like this and order everything on monday with same day delivery- Arya stealth is out, am I right?
Dang, the shiit is 320€ in germany - this is way to much. Then I could get the Topping DX5 II for just 300€... what do you think about the other listed amp/dacs and what would be your recommendation now that you know I'm based in germany![]()
And don't forget that software PEQ is a thing. If you're on windows, equalizer APO with peace is even better than hardware PEQ because you'll have virtually infinite sampling points and a lot more PEQ possible bands. I don't know how well it would do against the most invasive forms of anticheat, though. It's fine on VAC, but I don't know about kernel based solutions like Riot's.
Also, I don't mean to badmouth topping, but they have a long streak of QC and durability problems. The DX5 II just reviewed here, for instance, is waiting on a firmware update for the PEQ function to... function.
With this in mind, I gravitate more heavily towards FiiO and their K7 desktop amp or, even better in your case, the Bluetooth dongles like the BTR17. Once in balanced it should drive the 560s with ease, and if not, just use the desktop mode. With it you'll only be missing out on heavy EQing (things like adding a 10dB bass shelf). Oh, the Bluetooth dongles also come with PEQ, just like the DX5.
