Want to improve or change things up with my current setup, any ideas?
Gaster602
Hello, I am currently using a Oppo BDP-105, SMSL D2R, SMSL P2, Arya Organic setup. I have no major complaints for my current system, so I am not looking to replace anything. I am actually looking for something like a pre-amp or a hardware Eq, to change the sound more to my liking.
I am not looking to spend a lot, if I am to replace something, my budget would be to sell one of my current equipment plus 200 US dollars. If I am adding a pre-amp or a hardware Eq, I can perhaps raise my budget to 400 US dollars.
Please leave some of your ideas here!
Just use digital tone control.
A pre-amp is not needed for your setup and will only bring extra inputs you are not using and a nicer feeling volume control.
Even putting something as simple as a Schiit tone control (Loki/Lokius) can do what you might be looking for.
I am using my BDP-105 as the source though, so should I get a hardware tone control like the Schiit Lokius you are talking about?
One idea, maybe it's of interest.
The Oppo has 2 digital audio outputs, so however it is connected to the D2R you could add another path.
A WiiM Ultra could get the signal via optical. On it you have all the features to process, EQ, RoomFit, a nice app, sub management etc. and also to use it as a streamer. Then output that signal digitally (USB, also optical or coax) to your D2R.
It is one of the options you have and would be an addition that allows you to actually affect the sound.
A pre-amp won't regardless how many people claim to hear worthwhile improvements.
You would need a pre-amp if:
  • Your volume control does not work 'nicely' or has too little adjustment range
  • You can't go loud enough
  • You need more inputs than you currently have
  • Need a phono pre-amp input
  • Have 2 power amps close to the speakers
  • Simply want an extra box, even when you don't need it but looks cool
  • Need to have different input/output connections (balanced for instance)
You don't need one to 'improve the sound'
The Lokius will transform the tonal balance/sound any way you want/need and is very easy to operate.
But I heard the band of eq on the Schiit Lokius is too wide.
Perfectly fine as tone control and that's what you need.
6-Band Balanced Tone Control
Just 6 knobs to tweak the sound to your exact preference
It's not an equalizer but a tone control as it doesn't equalize anything but rather effects the tonality in rather wide bands.
I know Schiit also uses the word 'equalization' but that is't technically correct.
Two completely different scenarios.
Using that disc player as a mch source, to get tone controls or (even better) PEQ that needs to operate on its **output**, probably a PC with mch interface would be cheaper than trying to coordinate clocking with multiple 2ch units.
I suppose you could try the analog path, maybe not all channels require adjusting?
For using the Oppo just as a stereo DAC, then you could EQ upstream.
So, to summarize, there are several options:
  1. Add a Tube buffer/pre-amp, however, the actual effect this has is highly debatable.
  2. Add a tone control, namely, a Schitt Lokius, the cost effectiveness is high, and the change would be substantial.
  3. Add another digital source with dsp and eq, the most proven method, but I only recently purchased my Oppo BDP-105, I am afraid it may side-line it, or be redundant a bit.
So, what do you guys think?
3. Dsp and eq. You can do anything this way without loss. Only positives, mainly in speaker/room integration which in practice means better sound that is tailered to your room and preference.
The only things to keep in mind:
- Are you expecting great usability/quick results without much effort?. If yes, choose a device which automatically caculates an eq responsive. Ie a Wiim roomfit. Of you are a tinkerer and engineer choose Rew and measure yourself.
- eq only under 750 hz and above that sparingly. I use a downslope on treble for my Genelec speakers for instance.
- use a good microphone like a Minidsp Umik.
- measure and apply, take a few days to get used to it. And repeat if needed. Try to get a feel for what effect your changes have.
First and foremost I would recommend to share and optimise your speaker position and listening postion.
Actually, I am using headphone, Arya Organic is a headphone.
option 2 if you just want some tone control.
option 3 if you want to correct the Arya to some target of choice to a recommendation of someone that measured it to some standard (your ears most likely do not conform to that standard anyway) and from there on EQ or change the EQ to your preference/taste.
forget option 1.
The way I see it, all you need to maintain as a HP user before/after anything, is a good SNR.
And for that, gain-staging is everything.
Make sure that all your chain maintains a good bit of it.
I'd do Oppo->Optical->WiiM Pro->Optical->SMSL->Arya.
With that you can do precise frequency response correction and tone control in the WiiM Home App.
And you get additional but fully optional streaming functionality which can be nice to have.
For Optical in -> DSP -> Optical out, the WiiM Ultra or WiiM Pro Plus offer no advantage over the WiiM Pro, so may as well save the money and desk space.
And to correct the Arya Organic, copy the Frequency, Gain, and Q values at the bottom of this PDF into the WiiM Hone App, then tweak the gains of band 2,6,8,10 to preference according to the instructions:
That being said, be aware that you could consolidate the WiiM, SMSL D2R, and SMSL P2 into a Topping DX1 II with no loss in sound quality.
The SMSL stuff feels premium, looks nice, and may give you a sense of pride of ownership, but with a headphone as easy to drive as the Hifiman Arya, that's basically it. They're not doing anything useful to sound quality.
Silly question - what is your age?
Have your hearing checked.
The Oppo is a very good source!!
Buy an inexpensive laptop and connect it to your DAC via USB. Rip your entire disc collection to the laptop's hard drive, calibrate with GSonic Reference, and use Camilla DSP to convolve the resulting correction filters. The laptop is the only cost in this setup (if you don't already have one).
Calibrate the Hifiman Arya with GSonic Reference?
Sorry didn't see it was a headphone. And definitely don't calibrate it with GSR :)
