I want to understand the expertise here in this forum, regarding this...Why not ask WADAX?
Why? For what purpose would it serve you?I want to understand the expertise here in this forum, regarding this...
If you do a preference test, there will be a reported preference at each trial. Because the subject will be asked to do that.You can just do this for DACs as well. You’ll end up with an equivalent result: there will be no preference, meaning people cannot tell one from another.
I think you've confused marketing copy for technical documentation.There is no scientific reference to Hilbert Mapping in digital-audio system design?
All that matters is if the DSP has an audible effect.Is this DSP only looking at noise related jitter or is it an amalgamation of influences in the DAC architecture that are under control...?
Can't see if Wadax have any sort of Warranty for their products. At these prices, about a hundred years would be reasonable.
Coax the forum members to justify some unknown and undefined technobabble.Why? For what purpose would it serve you?
ExactlyIf you do a preference test, there will be a reported preference at each trial. Because the subject will be asked to do that.
But if the DACs actually sound the same, their will be no significant pattern to whether A or B is preferred.
If the subject reports that they can't decide (A and B sound the same to them) , the preference test is over.
You would be the expert on this given you are nearly 100 years old and a Tolkien expertCan't see if Wadax have any sort of Warranty for their products. At these prices, about a hundred years would be reasonable.
But isn't this rationalization beholding to a construct of 'transparency' in which to rationalize a construct of 'coloring'? ...All that matters is if the DSP has an audible effect.
If it does, that will be indicated both in measurements, and in double-blind level-matched listening tests.
Also, if it does, the DAC is not aiming for transparency: it is audibly coloring the output 'on purpose'.
lol wutBut isn't this rationalization beholding to a construct of 'transparency' in which to rationalize a construct of 'coloring'? ...
The most salient aspect is whether or not the resulting subjective psychoacoustic interpretation is aesthetically pleasing in juxtaposition to a $200 DAC or any other DAC that implements a similar technology... Obviously given the reality, it is all speculation... So, I thank all that were a bit more professional in their responses, I've got a good feel for the atmospheric conditions...
A dac has one job: accurately convert a digital signal into analog. Measuring its accuracy is easy and thorough and there is nothing about it that isn’t measurable. If a dac sounds different from an accurate dac, it is an effects box not a high fidelity converter.
Understood... However, 'accuracy' is an interpretive construct and extrapolation from a set of measurements... we only 'hear' the results of the interpolation as produced by the DAC platform, which is always beholding to subjective assesment.... So again, we come back to semantic and connotative bias... I hear the overarching rationalization... all DACs sound the same, because they do only one thing... convert digital-audio signal into analog energy....A dac has one job: accurately convert a digital signal into analog.
If you insist on it, you may continue to believe that a focus on objective performance is a "bias," that is fine, go for it. Because it is definitely a fact that this forum is dedicated investigation of objective performance. But maybe that's not for you! The good news is that virtually every other hi-fi community and forum and publication is the opposite, focusing primarily on sighted, subjective response, so the kind of approaches you seem to be looking for can easily be found elsewhere and you can ignore ASR.Understood... However, 'accuracy' is an interpretive construct and extrapolation from a set of measurements... we only 'hear' the results of the interpolation as produced by the DAC platform, which is always beholding to subjective assesment.... So again, we come back to semantic and connotative bias... I hear the overarching rationalization... all DACs sound the same, because they do only one thing... convert digital-audio signal into analog energy....
