W.T.B. Belden 8806 speaker cables for project.
I wasn't particularly focused on ferrites, and have never had any make a difference IME.
What are you focused on? What is your technical background (don't what to talk down to you nor over your head)? This comes up often enough that a short article might be worthwhile, but my time is limited lately, plus since retiring I no longer have ready access to test equipment to demonstrate the practical results.
Clearly my experience differs substantially. I think I still have a box of various ferrite cores someplace in the black hole masquerading as our storage shed. Ferrites work in some situations, not so much in others; it all depends upon the system, where the RFI is entering, and where it is being demodulated to audio. They are a cheap and easy fix in many cases, and when they don't work, troubleshooting and resolving the interference problem is usually much harder.
A common example of ferrites on cables is the cylindrical "bulge" on many video monitor cables. That is a ferrite core clamped around the cable to reduce radiation and meet FTC specs for consumer gear.
I'm not much into car audio, tho.
Me either, but when I did a quick search for ferrites for audio, they seemed to mostly target cars. It was by no means an exhaustive search. For myself, the biggest use of ferrites for car audio was on power and speaker cables to reduce alternator/generator whine. My foray into car audio installation was fortunately (yet painfully) brief.
This is not how we speak here, much less to one of our technical expert.
Thanks Amir, that was a reminder of why I quit posting here, but I hope to be able to explain enough that some folk can follow. Came back for a bit because I actually saw your name mentioned in a recent article about the MS audio stack, which mentioned you and your team, and even your "transition" to ASR. I am quite sure the implication that ASR was paying the bills now was false, however... ;)
Clearly my experience differs substantially. I think I still have a box of various ferrite cores someplace in the black hole masquerading as our storage shed. Ferrites work in some situations, not so much in others; it all depends upon system, where the RFI is entering, and where it is being demodulated to audio. They are a cheap and easy fix in many cases, and when they don't work, troubleshooting and resolving the interference problem is usually much harder.
My apologies, was talking out of my backside.
FWIW the specifics of a particular cable was my main issue....and the uselessness of ferrites in many home solutions. Sorry in any case....
Thanks Kevin, a great list! I let my AES membership lapse decades ago since my career took a different path and didn't think to include them (let alone Jim Brown) in my list of references. I was not very specific in my references; my excuse is it was late, I was tired, and frustrated at life in general (stuff going on at home, and a break to relax and look at ASR turned into a vexing experience, natch).
Cable shielding is a whole 'nuther can of worms, probably beyond the scope of this thread as it is, but suffice to say that like ferrites the importance very much depends upon the system and type and level of RFI involved. The best shielding for audio is usually a fully differential, or at least balanced, shielded cable using XLR or TRS connectors, but how well the shield works depends greatly upon proper grounding techniques (the dreaded pin 1 problem). That shield needs to go to chassis ground separate (isolated) from the signal return (reference), and even professional gear has been known to screw it up (to be blunt).
Other than shielding and pure mechanical construction quality, audio interconnects for home use are pretty much a solved problem. Speaker cables need to be large enough to carry the current and not increase the driving point impedance (or lower the "damping factor") at the speaker unreasonably (I have articles here about that, and there are numerous others online and in print). Basically big enough to do the job, with decent connectors (and connections), done.
IME/IMO - Don
Some of the best Audio Engineering Society papers ever!
Includes the original Neil Muncy (RIP) "Pin 1 Problem" paper and several others.
Download or a print copy for $33.
I keep thinking I should rejoin as an associate for a year just to peruse the library. Harder to justify since retirement; a big "want", but not a "need" per se.
