VU Meters: Let's See 'Em!!
Ralph_Cramden
Andysu
After replacing Cat-109 with new VU meters that are commonly used in a CB radio cobra 148GTL-DX or that I noticed with my sueprstar360FM I ordered x6 meters
Next was testing them in Dolby Stereo CP200 (can you guess what film)?
Andysu
Next step was to wire the bulb up as nearly all Dolby Stereo CP200 that I have seen in the past years at the local ABC 1, Bournemouth, (London) Odeon Leicester Square, Odeon west end, Warner west end, and Empire Leicester Square Empire 1, near all never had an illuminated VU meter so I thought I do it with mine.
Andysu
Thou I fitted soldered reisotor to the bulbs a surge peak when switching it On must have blown the bulbs, no matter I have some white LED that I will eventually install, when not feeling depressed as not having my Cat, Sooty around anymore has left a huge deep wound, thou I may have new Cat Bear, and my other adopted Cat, Magic, I still find each most days now extremely difficult.
Andysu
Yes over the short time the bulbs have slowly blown and ones in most CR radios I have have lasted 40 years or more. I think I should have fitted a higher resistor first time around and thou I never actually checked with the multi-meter what voltage reading if it was 12v that is far too high and should have been at least 6v or 5v. I not sure if any bulbs are still working.
Andysu
Between soldering the Cat-109C while feeding my Cat, Magic a meaty stick.
Andysu
Sooty appears in the video and has a scratch at the carpet tiles.
watchnerd
Seattle Area, USA
Is there some advantage to using a commercial cinema processor at home?
Or is it just for fun?
Ralph_Cramden
Cool setup. Those displays make the RME look big, until I realized they aren't the standard 7" "official" units. What hardware are you using?
Hyperpixel 4" touchscreens in two of these cases:
Two strong magnets in the bottom of each case holds them VERY securely to the RME.
If you want to use a Pi 4, this case should work with the Hyperpixel 4" touchscreen.
TunaBug
Seattle-ish
Thanks. I think... I have stuff I'm supposed to be doing and it doesn't include checking this out.:facepalm: But I've added it to my TODO list.
pjug
Looks like Radio Shack is targeting ASR members
