jimijoeb
Wires are so thin that it will cause minimal mechanical load on solder joint.What about this thin secondary power supply AC wiring with just solder holding it? Looks dangerous...
Except they do offer this one at $1039 which is an exact copy of what Amir originally reviewed--with speakon outs.And this is why you build your own folks:
~$750 Amplifier board (https://purifi-audio.com/vare/eval1/)
~$250 Chassis (https://www.ghentaudio.com/kit/purifi-eval1-se.html)
~$250 Hypex 1200W PSU
Yes, this is the standard layout for the VTV's with the Hypex or VTV buffers that permitted op amp rolling.It is VTV's more expensive model with dual power supplies.
The VTV standard model with single power supply seems to be a more sensible build.
I’m very happy with my monoblocks!so far im getting the apollon purify.
Most things in there use solder, it's very strong. And prevents fraying. Try ripping out wires or capacitors without desoldering.What about this thin secondary power supply AC wiring with just solder holding it? Looks dangerous...
What're we looking at?
Is there a fuse? And if so what is the rating?
Safety advice (Or rather, a requirement)
The screw of the ground wire should be done in such a way that it cannot be unscrewed from the outside. From the photo it looks like a nut is inside the chassis while the screw head is outside the chassis.
Example using bent / stamped chassis
https://www.audiosciencereview.com/...-opamp-review-sonic-imagery-vs-sparkos.10325/Great review @amirm !
Most of the concerns would be easy to solve so hopefully VTV is watching? The small wires going from the trigger to the mains is very concerning. The other small wires only cary 12v I believe?
I should point out this amp has Sonic Imagery Labs 994 Enh-Tricha https://vtvamplifier.com/product/so...ticha-dual-discrete-opamp-dip8-vtv-amplifier/
and not the 990 Enh-Tricha which you state which look like this https://vtvamplifier.com/product/pa...90enh-ticha-discrete-opamp-api-vtv-amplifier/
Probably not a big deal to the measurements but the 990 opamps are API pin out and a bit more expensive while the 994 are DIP8 pin out.
You should measure the amp with the Weiss OP2-BP opamps https://vtvamplifier.com/product/weiss-op2-ba-discrete-opamp-module/ to see if they are worth the extra money based on performance?
Would also be interesting to plug some much cheaper OPA1612 chip amps in the buffer just as a baseline?
Lastly, any logic to measure the amp with the buffer set to +7db gain rather than +14db?
