Hello from France
State of the art require that the right connector is used !
In that case it should be FC-16P Connector with pitch 2.54mm
View attachment 64675View attachment 64676View attachment 64677View attachment 64678
And the connector used by March Audio on his P502
Are you calling state of the art the use of a connector designed for ribbon cables with standard wires?
If it works for Alan, good for him, but that is clearly not the proper example of "the right tool for the right task".
Yes we use the correct connector. The miniature Mogami balanced cable is the correct size conductor to fit into the compression pins. There is no difference in terms of quality of cable termination to the connector between the balanced cable and ribbon cable.
This means a screened connection directly to the connector instead of ribbon cable or additional PCBs and connectors.
Zero issues with this on the hundreds of amps sold.
