C. Cook
- Joined
- Sep 21, 2021
- Messages
- 366
- Likes
- 185
- Thread Starter
- #41
But you're mixing up whose design is deficient. In the case (pun not intended) of heat sinking it would be Ghent, not VTV. And tons of other OEM Hypex products use Ghent cases with no additional heat sinking. IF it was a huge problem, don't you think we'd have heard something by now?You are missing the point. you running your amp at very low levels is irrelevant. the amp is sold as delivering 700 with into 4 ohms. it will be in meltdown at that level.
Now turn the amp over and measure the base temperature and the box internal air temp.
What other manufacturers do is irrelevant. You need to stop making apologies for this deficient design.
Now I'm not saying Ghent's case is the ideal one to use for this application and I'm also not disputing that your amp was a shitshow and I'm glad you were able to recoup your money. But again, it is completely relevant if we're limiting our discussion of the design to the heat sinking characteristics for me to want to see any other OEM mfg. that's actually using the fin-type HS you showed. I don't think anyone is, hence everyone else's design is also deficient according to that logic. That said, I repeat there were OTHER glaring issues with the one you got, so I want to keep this specific to heat.
The measurements I took were at the bottom of the amp, no need to turn it over. I also used the feel test. Never got hot enough to make me want to take my hand away and running much cooler than the last good A/B amp I had, as expected.
Nobody realistically expects to ever tap into the 700th watt or even close, at least not in any continuous fashion. Like it or not, the heat issues I was experiencing on day one are gone now and I am not sure why, but I have no vested interest in the success of VTV and therefore no reason to lie or intentionally misunderstand what's happening. At some point I *MAY* get in there and fix up a few of the minor soldering issues and lack of shrink wrap on some of the inside terminal wiring.
