radix
- Joined
- Aug 1, 2021
- Messages
- 1,397
- Likes
- 1,334
By flash drive, you mean a thumb drive? I do have those flake out on me every now and again, especially under higher loads. If you put the thumb drive into your PC and try playing from the PC, does it consistently work?SB flash drive from Sandisk. Even with compressed FLAC's my entire collection fits on two of them (at 256 GB each)
I would try to check the volumio system logs. My concern is that if you switch to a different OS, it will have the same problem with the drives.
What output device are you using? USB to a DAC? If you are using a USB source and a USB output, maybe volumio OS is getting confused? Personally, I'd use the USB3 for the drives and USB2 for the DAC, if that's the case.
You could try downloading Roon Core for Linux, flashing a new SD card (to keep your volumio card intact) and try Roon with a trial subscription. I've not installed it on linux before (I use a nas install as I said).
If you use "lsusb -v" you will see the maxpower of each device. I believe the 4B can support up to 1200mA of USB power.
