You have missed an unavoidable fact about DSP. I agree users of DSP should limit its adjustment zone to sub 500 Hz or even less. BUT there is no way the higher frequencies can avoid encountering the DSP - digital signal processor – unless you pass the full signal though an active XO first and send the top end to a non-DSP amp while the bass goes through DSP and its own amp.That is another bunch of codswallop. More advanced DSP software lets you do what you want, and you can choose to leave the high freqs alone if you want to. In fact, I suggest that most DSP users leave the high freqs alone, unless they have high confidence that they have taken proper measurements and they know what they are doing.
With typical amps with built-in DSP the ENTIRE SIGNAL has to pass through the filter despite adjustments being made to the bass only. As with any unnecessary processors (eg tone controls, graphic equalisers digital processors) there is a loss of ultimate sound quality. Don’t believe this? Just switch between No Filter and DSP filter when connected to very high-quality speakers. Play a bass-light track with plenty of top-end detail and you’ll hear the loss of top end detail.
Do you really believe that music couldn’t be reproduced in the home pre the invention of DSP? Perhaps in those days, people took a bit more care in choosing and setting up their kit. DSP is no substitute for this.
Keep your codswallop to yourself! Do you know the origins of that word by the way?
