Madhoose2k
- Joined
- Jan 27, 2025
- Messages
- 4
- Likes
- 0
Hoping someone can advise. An old relative that is partially sighted and uses a hearing aid (age 101) used to be chair bound right next to his stereo and was able to reach the volume control so he was able to listen to the radio. Now his health has taken a bad turn and now is bed bound in the same room. He lives in silence and badly misses his radio. Here’s what I propose …. Run A long headphone lead to a speaker by his bed with a fitted volume control to a 1G plate on a surface back box in the shape of a 1k potentiometer audio taper. Connected this to an 8ohm speaker to be placed by his bed.
the volume was adjustable and clear but due to him being hard of hearing he couldn’t hear it.
Take two I used a powered speaker and tried fitting the pot inline between the source (headphone output jack) and the powered speaker but the level was constant, I was hoping g I could adjust the level going into the speaker input but the pot wouldn’t work.
Do I need to use a different type of pot? Surely just need to set the level on the active speaker then the pot on the input line should just alter the input signal hence giving volume adjustment.
Thanks for looking and hope it makes sense!!
