Volume at 100% using monitors with TV, will Dac with remote help??
Any chance you or anyone else knows if this will work for a PC?
I hooked these up to my pc, got the volume at 10% and getting a decent amount of noise. I can't do gaming at all, the noise is insane. I even tried to do a workaround by using my monitor's audio selection and no luck at all, just a massive amount of noise once the GPU kicks in.
The only thing worse than an LG tv is a windows 11 pc. It's another piece of absolute shit I should have returned instead of just thinking it just needed a couple of fixes.
If I have to buy a more expensive dac thats 100-200 bucks I'll do that if it kills the noise once my PC and TV.
I believe the unit you have is just plain bad. The ones linked earlier are dead silent per their measurements.
