OK...here are my thoughts. First, I have wondered how this amp would do in comparison to a Rega IO and mine, a Keces E40. The results clearly show it isn't on par. That said, I find my Keces E40 an excellent performer, just as other stated regarding the Spark II, however, I can make comparisons from experience.
I auditioned a few Fosi HD-A1s, yes a few because there was variability in each regarding SQ, the level hum and how hot the case got. All went back once I bought an Aiyima A04 amp. The Aiyima was much , much better in SQ. The Fosi, possibly the Spark II masked microdetails and other details, quite frankly the Fosi sounded dark to me. Cheapaudioman stated the Spark II reminded him of his SimaudioMoon amp if I am not mistaken, meaning it sounded brighter rather than darker.
I liked the Aiyima A04 so much that I wanted to have the Aiyima A07 which came with its' own 32v PS but I also bought a 36v for more power output. These class D amps are nice, can easily travel, just nice to have.
That said, I found out about the Keces when I was looking at class AB amps in a smaller form factor. One reviewer, Soundnews, reviewed it favorably and even ended up with a larger amp from the same company, so I was intrigued.
The US distributor doesn't allow for returns. You buy it you keep it which may turn off a few people. But I took the chance based on Soundnews and a few other written reviews. In the end, I am happy with my purchase. In comparison to the Aiyima class D amps which I like, there is a bit more detail. depth and separation. It has more bite vs the more levelness of the midrange of the class D amps. I have used Focal, Triangle and Cambridge Audio speakers, as well as others. The Triangle do nice with all but the class D and Zeta combo is really, really nice. The Keces plays well with the Zetas too.
The Focals I have prefer class AB, perhaps due to more current delivery. The Keces is stated to be able to deliver up to 15 amps while the class D amps I think have a 3 amp capability.
Regarding bass, the Keces adds a dB or two at the lowest octaves but the bass isn't loose, it's tight. It adds just the level of warmth I like. I think the frquency range is 5Hx to 100K Hz which is nice.
As to SQ, I like the Keces better, but I also like the Aiyimas. The Keces, if I were to make a comparison, sounds very much in the same vein as my Hegel h160 at low to moderate volumes. I am comparing a 40 watt vs a 160 watt amp, or a 6X price difference.
Still, the little Keces performs admirably at the volume of loudness I listen to. So taking the Spark II off the list, the only one remaining is the Rega IO which is a 30 watt amp.
As to the Keces, some advertise it as a 50 watt, some as a 40 watt. What it actually is, is closer to a 35 watt at 8 ohms. I found one test on it which can be found online.
Using useful results, it seems to have have under .02% distortion starting at under 1 watt, the THD is lower than .02% and decreases to .008 THD in the range between approx. 5 to 14 watts, jumps to .01% but still under .02% up to 33 watts...this is all under a 8 ohm load.
At 4 ohms, the results are even better. with distortion staying well under .01% up to approx 27 watts, remaining at .01% up to about 45 watts and under/at 02% up to approx 58 watts.
So, I would call it at 33/58 watts at 8/4 ohm loads (test loads) respectively. At 1% distortion, it looks like the power output is about 36 watts at 8 ohms and 63 watts at 4 ohms. The unit can be found online and sells for $599, the same price as an IO.
It comes with a MM input, a usb input, a preout and two RCA inputs. Out of looks, I prefer it to the IO but the IO is nice too. These are the onlt two class AB amps I know of in this small a form factor I can recommend looking at. The Fosi I didn't like even though I gave it four stars on Amazon...I was nice. An Emotiva is a possibility as I have heard a BasX A400z in comparison but still preferred the Keces. The BasX a400z did have nice extended and airy highs though, more so than the Keces E40 but the E40 has better tone, separation, mids and depth.
Quite frankly, it sounds like a mini Hegel. Perhaps the distributor should send a test unit in to Amir. I think, not sure a test unit was sent to Soundnews,
I have a Lavaudio DS600 hooked up to the keces. It's fine for movies, sometimes a bit of glare or to much of mids with music but it's still decent. I think I am used to AKM chips with their smoothness for music but for the price, it's a great combo. Size wise, it doesn't get any smaller than that if you want a good class AB performance.
Power to distortion graph can be found on
www.hifitest.de for the Keces E40 (really, they should call it an E35) use google translate.
Any comments, thought appreciated. If you are an IO owner, I would like to hear your experience.
