The problem would be calibration of measured input versus actual voltage. If you just deal with relative values, then sure, you can do that.
Also, make sure you don't try to measure anything with high frequencies like squarewaves and such. The sound card will not have the bandwidth to sample those correctly.
On the other hand, you get far better resolution for audio than any scope. The ADCs are usually 8 bits due to need to run at super high speeds.
