Virtual 7.1 Surround Sound processing in Headphones
I'm still with the G6, I found it quite better compared to the trial versions of Dolby Atmos for Headphones, windows sonic, Razer THX, and the dolby headphones implemented in the old Logitech G35 headphones. I also really disliked the GC7's SXFI, it had a lot of reverberations while the SBX surround is relatively clean. I did have a GC7 and quickly returned it to buy a cheaper smaller and supposedly better engineered G6 as I only liked SBX anyway. The G6 is nicer on the table as well with smaller size and better volume knob and small simple SBX on/off button (I prefer to disable SBX for stereo content). I set my surround parameter to 33, I found that gives me the best separation between front and rear sounds, which are apparently the most difficult to simulate (they were almost indistinguishable with Atmos and Razer THX, even when setting the Razer THX to be as much "rear" as possible).
My last try with virtual surround solutions for headphones was with APL Virtuoso. I bought it for my personal use. First impression was very good for watching modern movies on headphones, for example. I kept using it for few months before I lost interest, though. While it works very well for some, it didn't for others. Reverberation is an issue. And there are quite a number of configuration options IIRC, so I probably lacked enough knowledge of the different options to get the best out of it. Also, it didn't help that it requires a virtual cable device for it to process the sound. I appreciate minimalistic solutions when possible. All in all, whenever I feel like watching a movie on my headphone now, which honestly it's also becoming rarer and rarer these days, I simply use Windows solutions (dolby or DTS). They are not perfect, but are simple to use and are decent enough for spatial sound on headphones, for me at least.
I've been using stereo sound and not virtual surround sound for a very long time.
I'm wondering if anyone has experimented with anything new in the past 3 years? Seems this forum has been a bit quiet so I'm intrigued if there's been any developments recently.
A lot of people seem to be praising sound blaster, but I'm wondering how people compare it to HeSuVi and if there are any new experiments with getting these options closer together? I see that one user tried to record the surround sound but didn't record anything, probably a protection mechanism.
Has anyone tried to record this with a separate microphone not connected to the sound blaster, or used a separate machine to make a recording?
It seems there's also been an update to Dolby Atmos:
I'm currently running the Aune ar5000 headphones.
I've decided to buy the SB G6, got it used for a decent price, so I'll experiment with the virtual surround sound and see if it's possible to get a good replication of it.
It's a shame that sound blaster doesn't seem to be in the high end anymore for their external DACs, like the old X7.
In my experience I think that's a good decision you made re buying the G6 for your virtual surround. In terms of trialling different surround options there was one user in this thread that made different sound files that had been processed by various virtual surround options that were available at the time, and it was possible to listen to those files and work out which one worked best for you in terms of locating front & back and to the sides accurately - so have a look through for that if you're curious to try some different options. He manipulated the original fraunhofer file that I linked in the first post of this thread.
Since you are using Windows, and in case you want better fidelity, you may try Equalizer APO to get rid of the virtual audio cable.
SXFI is absolute poison in my Creative Sound Blaster X1. I scanned myself several times and created numerous profiles, but it always sounds like hearing audio from another room. Truly the worst virtualization I have ever experienced. GEN2, GEN3, whatever. It is terrible.
Hello,
Thanks for the suggestion. Yeah, in fact, I've been using Equalizer APO on Windows for years. I use it because it allows me to apply system-wide PEQ, which is something I always do. I use Oratory1990's PEQ presets. :)
SXFI was just too much reverb for me. Probably had also other things causing it to sound bad but not something specific I can point my finger at. I returned the GC7 and ordered a cheaper smaller G6 as I ended up just using the SBX virtual surround.
Hi i tried the test on PC using the G6 with HD 560s and find out that 33% works best for me
I wanted to ask you some questions
1) i used the G6 exclusively for gaming on PS5 and i set it up with the optical cable instead of just USB to have acces to SBX so i put the PS5 on AV Receiver ans 5.1 with Dolby Audio and on the Sound Blaster Command i put it on 7.1 but i have a doubt even when receiving 5.1 Dolby Audio signal the 7.1 still works? Or should i put it on 5.1 in sound blaster command?
2) this is related to the 5.1 option on PS5 since it gives me an option to adjust the position of the speakers for example by Default both front speakers are in a 30° position and the ones on the rear are in 110° position so my question is does this affect the virtualization make by the G6 in any way? If so what's the proper angle for the speakers to work best?
Thanks for your post btw i finded it really useful for using my new G6
Find attached a couple of pdf files that show the speaker layout for 5.1 & 7.1. There you can see the differences, so if your PS5 is outputting 5.1 then I'd change the G6 to 5.1 too, that way you're not getting any conflicts. I think theoretically that's the best way to do it.
Hey thanks for the files i should try the the same test you link but this time using the 5.1 instead of 7.1 to find the best location? I downloaded the second file on your original post I'll check out in the first link to see if theres a 5.1 test
It looks like there's a 5.1 test according to the speaker layout albeit they don't call it specifically 5.1, but the speaker layout angles look correct:
and it's from this web page:
and it's described as "HE-AAC Channel ID - With H.264 Video"
