TBone
- Joined
- Mar 16, 2016
- Messages
- 1,191
- Likes
- 348
I've heard so many expensive vinyl rigs that weren't set up optimally....so much wasted money.
TBH, due to laws of diminishing returns and the frequency of bad set ups, I'd say a mid-level tt/arm/cart, with appropriately matching components, truly properly and carefully set up, will do better than a mediocre set up of a much more expensive rig.
Perhaps diminishing returns and bad setups are synonymous.
I don't happen to be a fan of the looks, but the new Technics 1200GR (~$1700), plus matched cartridge of choice in the $500-$1000 range, is probably the major inflection point for serious diminishing returns. Maybe an arm upgrade, too, if you want really want to gild the lilly or just be different. After that, it takes a lot more effort and money to do objectively better (different, yes, better, maybe not).
I like the look of the 1200, really luv the motor, the rest of the 'table, not so much. It certainly represents fine value for the money, but ...
For example, my previous Project Debut Carbon came with an Ortofon 2M Red and the fixed carbon tonearm is well optimized for this. But if you want to upgrade to a 2M Black, things may not work out so well, as the 2M Black has a much narrower stylus and sensitive to VTA/SRA....which isn't really easily adjustable on the Debut Carbon arm.
The VTA/SRA myth ...
Considering all the fluffy, out of date, potentially wrong or just plain wrong advice/data out there regarding stylus positioning ... perhaps this 2004 article is of interest.
http://www.tnt-audio.com/sorgenti/vta_e.html
Not dismissing the importance of stylus rake-angle per say; I'm mostly dismissing much posted VTA advice, and it's overall importance in the vast majority of systems ... which leads to the myth. Measurements, those done with a variety of carts (measuring IMD @increased VTA) consistently show that rake-angle accuracy is of less importance than is often stated.
http://www.milleraudioresearch.com/avtech/
All too often, even with the aggressive stylus on expensive carts ... stylus rake angle adjustment can prove insignificant.
My own measurements only confirm much the same.
Level 5 test (hardest test track), L/R channel, lateral modulation, 100hz tone. The number represents the tracking force (100=1 gram, 150=1.5grams).
(IMO, the most critical time to properly set a cartridge for life; is to measure during break-in. If set incorrectly at an early point, and used in that manner for a prolonged period, you've most likely negatively destined that cartridge's full potential.)
Below is the current set. Sets are recorded at different intervals during cartridge break-in, starting from about 5hrs play to the current ~25hrs. Sets can be compared to prior sets utilizing various VTA and anti-skate settings.
below graph ...
130DR = 1.3gr, non parallel arm +VTA.
1.12R = 1.12gr parallel arm.
(note: stylus rake angle is defined by VTF and VTA setting.)
While I can display graphs that show a little more measurable differences with VTA/VTF, especially over time, they all remain relatively consistent.
The 2M Black is a polarizing cartridge. People love it, people hate it. I'm not surprised.
The 2M uses the Replicant stylus, like the FG-S its an aggressive cut which requires azimuth be near-perfect at all times to maximize its potential. That happenstance occurs more in some systems, than others. The negative influences of improper azimuth rears its ugly-ness rather quickly, and becomes that much more subjectively critically.
Azimuth remains the most critical stylus orientation. Rake-angle(VTA/SRA) is of little concern when azimuth is not optimized, especially for carts like the Black.
