I found these unknown Altec speakers at a surplus store:
They're $100 for the pair. Is there any potential use for these little guys or they simply relics of the past?
EDIT: Dang! Beaten to the punch --
twice. I am slippin'.
Oh, I thought this was the
other Altec thread that's popped up here recently!
(I
knew this place would come around eventually...
Check the dimensions. Those appear to be relatively early Altec Santanas (the earliest morph was known as the 879A).
source:
https://lansingheritage.org/html/altec/catalogs/1974-home.htm
They look a little
tired.
Are they worth a hundred bucks? Well... maybe...
The early Santanas would (
should) have one of the 15 inch Altec extended range "Biflex" drivers and large-ish cone tweeters (made by Altec). The Altec Biflexes have dual compliance cones (Pioneer/Fukuin also made drivers like this in the 1960s) to extend treble response
in lieu of a whizzer cone. They're well made drivers and can be re-coned to (if memory serves) be functionally identical to the famed 416 woofers. Biflexes
per se are of limited (but not zero) interest, but the
value of the cone and motor assembly is significant.
That said,
if the drivers are Biflexes
and if all the drivers are in good condition and functioning, there's probably $100 worth of value there.
N.B. Later Santanas ("Santana II") used much less interesting OEM woofers and cone tweeters and, unless one has a project in mind for their large cabinets are, I'd opine, best avoided.
Hope this is helpful!
@eddantes triggered me!
