wemist01
I'm curious if anyone has either first-hand experience with this or thinks that with the specs below it might still be equal to a Scarlett 2i2 using TRS jacks. I'm only seriously interested in ADC. The device is 10 years old at this point, but the predecessor to this, the SE-U55 (limited to 16/44.1), served me well 20 years ago, and the feature set was a lot of fun. I realized today you can order used models of the newer one from Japan for around $100, and might do it just for the fun of it even if it isn't a credible ADC by today's standards. But I would guess it still is. If you have a guess or a better-informed opinion, I'm happy to hear it.
Some of the below may not make sense as it was translated. The manual is here:
https://www.jp.onkyo.com/support/manual/manualpdf/se-u55sx.pdf
Format: USB Audio Processor
Connection method: USB 1.1
Input: 44.1/48/96kHz Compatible
Output: 44.1/48/96kHz
Frequency: 0.3Hz~44kHz (+0/-0.5dB)
Total harmonic distortion: 0.002% (20-kHz AES17 LPF, A-Weighted)
SN ratio: 115dB (20-kHz AES17 LPF, A-Weighted)
Line Output Rhel: 2.0Vrms
Line Input Rhel: 200mVrms
Microphone input sensitivity: 5.0mVrms
Audio input: Digital 3 (Optical 2, Coaxial 1), Analog 1, Microphone 1
Audio output: Digital 2 (Optical 2), Analog 1, Headphone 1
Power Supply*: AC100V 50/60Hz
Power consumption: 3.8W
Dimensions (width × height × depth): 169×244×67mm
Mass: 0.7kg
* When using power attachment (IU15-2050100-WP)
Mass: 0.7kg
