Vinshine x Kinki Studio: Tai Hang Power Enhancer
mediocrebutarrogant
Gents look! Alvin just showed how power enhancer brought noise down to zero in this video:
He shows connecting from mains his analyser gives hiss, then he connects Tai Hang and boom noise is zero and black background!
I only buy stuff recommended by ASR, but as Alvin says there are indeed times, when my system sounds better at 2 AM than at 11 30 AM , I am sure its got more to do with my poison of choice for the night and not really what Alvin says, but cant deny noise hum went to zero after connecting Tai Hang , so I am wondering if this is for real.
The hand-lettered Jethro Bodine quality sign is a delightful touch.
Hey! No politics!
:cool:
EDIT: And I'm not sure about the marsupial policy, either. :rolleyes: ;)
A friend ordered one piece 8 weeks ago. It still hasn't been shipped, even though it says the waiting time for dispatch is 4-6 weeks. No one is responding to messages (vinshine.audio).
Really a very bad experience.
I’ve ordered one from Magnahifi (EU version). Should arrive sometime next week :)
I’ve had nothing but good experiences after upgrading things like Powercords (to Supra Lorad silver) and adding Powerfilters like Furman AC210 / Ifi DC Blocker+
I might just be unlucky with a extremely bad Powergrid in my Area but if those gadgets actually made a difference, I’m looking forward to replacing them with the Tai Hang :)
Uh huh
The only way to truly be on the safe side regarding noise - including that nasty 50 Hz hum - is to fully eliminate the ripple from the mains outlet. To do this, you need a full bridge rectifier and a 4 kW resistor coupled to some beefy 600 V caps in parallel. The resistor will likely need a fan, too. Install all that into a nice case and position the plug of your HiFi setup loosely on top of that case. Ideally on some cable lifters. It's important not to plug it in to get the maximum isolation and the blackest blacks in the background. Enjoy zero noise forever!
With enough Tai-Hangs connected in parallel, one can completely eliminate the DC power supplies in their gear.
(Given the ratio of powdered Unicorn horn to Phantasm plasma is correct).
