Hi all,
I know vented box impedance traces have been covered plenty of times, but I’m still struggling to fully square a few things, so I’m hoping someone can help clarify.
With a typical vented enclosure impedance plot you get the familiar two peaks with a dip between them. I’d always understood that the left-hand peak was associated with the port and the right-hand peak with the driver resonance. However, in an AES YouTube video it’s stated that you can’t really say which peak “belongs” to the port and which to the driver.
What’s confusing me is that when you change the port size or block the port entirely, it always seems to be the left-hand peak that shifts, while the right-hand peak stays more or less where it is. That feels like it does tell you something about which peak is which, so I’m clearly missing a nuance here.
Using the usual terminology:
Overall, I’m just trying to build a more accurate mental model of what changes in frequency, amplitude, and peak shape are actually telling me when looking at vented box impedance traces over time or after physical changes to the system.
Thanks in advance.
- FL – left-hand impedance peak
- FH – right-hand impedance peak
- FB – box tuning frequency (the minimum between the peaks)
- If FL, FB, or FH move left or right in frequency, what does that generally indicate?
- If the height of FL or FH changes, what does that usually point to (damping, losses, Q, etc.)?
- Does the difference in height between the two peaks tell you anything useful? For example, one peak being much higher than the other, or the two becoming more or less symmetrical.
- Finally, with speaker ageing (changes in compliance, losses, suspension softening, etc.), what would you typically expect to see happen to:
FL, FB, and FH
Thanks in advance.
