Keith_W
With your answers, it is almost impossible to tell where the signal chain is broken.
However, I suspect that given that you said this:
If you get sound with VB Cable but not with VB Matrix, it is likely that you have configured VB Matrix improperly.
You do not need VB Matrix to send 2ch audio from Roon to HLH. Remember that the audio remains 2ch until it goes out of the Dirac VST! I suspect you misunderstood Mitch, or you told him something else. Maybe he thought that you were trying to send 4ch audio from Roon to HLH. I don't know. But for the software pipeline that you wrote, all you need is VB Cable or VAC to send audio from Roon to HLH.
Let's keep this very simple. Let's say you want to use an electric lawnmower. You don't have an extension cord long enough, so you make one up by joining a bunch of shorter cords together. Somewhere in there, you decide that it would be a good idea to include an electrical multiplexer which is capable of routing electricity from one source to another. You try to turn on your lawnmower, and it doesn't work.
The problem is that you are overcomplicating your system. Cut it down to the simplest system that will work. It will look something like this:
Roon --> Dirac standalone --> DAC
If it works, end of story. No need for VB Matrix, software cables, HLH, or anything else. But I can understand that you might want the extra functionality that you get from HLH, so the next step would be something like this:
Roon --> 2ch software cable --> HLH --> Dirac VST --> DAC
With VB-Cable instead on VB Matrix, I had sound on channels L & R when I use VB-Audio cable as Roon endpoint.
But Mitch from Accurate Sound, told me that I have to use VB-Audio Matrix to support multichannel (2.2) as VB-Audio Cable only supports stereo
