Hello,
Received the proposed installation suggestion from an installer.
What are your thoughts with respect to speaker placement and what upgrades / modifications would you make?
I am open to bookshelf or floor speakers also but the space might work better with in-wall speakers.
From installer:
“The Living room will be configured as a 9.1 home theater for movies and music with in-wall front and rear speakers, 4 side speakers using in-ceiling speakers with tweeters aimed down toward the center of the room and a subwoofer. This is basically a “modified” Atmos 5.1.4 configuration but without the “vertical depth” of a true Atmos configuration.”
1.) In wall speakers are great space savers however since they lack a true cabinet they do not have the same output/impact a full floor standing speaker normally does.
2.) Polks are a great bang for the buck. Thanks to their neutral and natural sound they perform well for music and home theater. There of course are other brands with different tonal qualities.
3.) The front soundstage was limited in placement to current furniture and the sliding door. Based on the distance from the seating area you would not want place the front three speakers too close together.
4.) Ideally placing the center channel below the tv closer to ear level is the best option if possible.
5.) Since your front and back speakers are close to the same height as the rest you would not get a true 3 dimensional feel. The Modified atmos design allows you to run the system as a 9 channel system but if your able to move the front and back speakers closer to ear level then the system can be a 5.1.4 system.
6.) All of the Polk speakers in the design have a swivel or aimable tweeter to help with non ideal speaker placement.
7.) In order to have it work in a modified atmos setup having them in the higher locations give them the height they would need.”
From installer:
