Richardjhy
- Joined
- Dec 11, 2022
- Messages
- 74
- Likes
- 4
I know that VA ratting is bigger than wattage, but why huge difference in this amp:
Holes are original. Actually there're 6 holesPower factor.
I guess the A-760's a pretty reactive load.
Now... I wanna know if those three small holes after the CAUTION are factory stock or aftermarket?
I don't know and I can't check -- because, amazingly, I don't have an A-760 in the Yamaha collection here?!![]()
There's a lot of additional complexity there which must generate a fair amount of noise, both into the amp itself and on to the mains supply.These also don't have just any old transformer power supply, it's a semi-regulated affair with sort of a dimmer on the primary. It's the exact type of amp for which I've described a power filter mod more than once lately.
They seem to be stock, see here the service manual with the same holes:I wanna know if those three small holes after the CAUTION are factory stock or aftermarket?
It's the power supply design that's reactive. As @AnalogSteph has said, this is a regulated AC power supply - it attempts to compensate for high and low mains voltage, and maintain a constant, even supply to the transformer.Maybe it sheds some light on the Watt vs VA curiosity?
Some older CRT television sets used similar principles to regulate the incoming power. They were notoriously unpopular due to the amount of noise they created on the mains supply (due to thyristor switching).
>> 20 years old.Nowadays PFC (Power Factor Compensation) is included in (many?, most?) power supplies. This amp is likely >20 years old...
