Three months on and I've continued to pursue this. In May added to a thread at the miniDSP community board on Umik-2 started by another member with an issue. Ultimately miniDSP authorized Deer Creek to verify mine. After some back-and-forth on side issues they said it verified against their reference mic and they returned it. I measured again, no change. I was close to pressing for a replacement, but continued to look into everything I could. I had asked the REW author if anything could alter the measurement, he said no, recommended what I had already looked into. So I kept digging into everything.
I was able to resurrect my old Liberty Audiosuite (LAUD) system. The Fiji card was fine, Win98 settings was the issue after repairing the motherboard some time ago. I measured the woofer again with it. It uses scripts to make the close-mic measurement using stepped sine after using an automated optimization of the mic and feedback inputs. It then uses the woofer diameter coupled with the calibrated microphone response to produce a calibrated measurement that is then modified to be represent SPL for 2.83V @1m. This is a DOS 3 program from 1998, has functionality I never even tried to use.
LAUD measurement. I set the markers to make it easy to read the slope. This confirmed that the old microphone used in it's low end matches that when used in REW in Windows 10 using the m-Audio 1010LT card. More on that to come.
For reference I ran loopback calibration for all of the unbalanced outputs of the 1010LT card used for the Panasonic and ModeCompensator measurements. Six channels almost all identical. For a nearly 30 year old card design. Purchased used on ebay some years ago.
When I started using REW I left all of the defaults untouched, but tried some change in preferences. I re-ran measurements with all mics, still found nothing until I looked closely at the most recent Panasonic REW measurement. It also had a downward tilt not in earlier measurements. Shortly after that I found the IR Windows option in REW (I was close to asking the author for similar). What I found was that the default window in REW is set for...measuring room response that needs a long window. Default is 500msec using a Tukey 0.25 window. That is how I left REW when making sound card and amplifier distortion measurements.
With some experimenting in REW I found that a close-mic measurement must have a short window that totally eliminates any influence outside of the driver and that the correct window is a Blackman-Harris. I experimented with the windowing for all three microphone measurements. Most important is the window length, second is the window type. All windows must, of course, go to zero. Several can be used such as Hann, but the Blackman-Harris seems to be the optimum for side-lobe control with a small amount of SPL magnitude.
The optimum window width for this 10" woofer with a 10mm mic position is around 100msec. Each measurement may benefit from a small change from this, +/-, more often -. The window width affects the low end extension as well. Other driver sizes may be slightly different due to mic position needed for the driver diameter, but 100mm will probably be a good starting point. The problem is that I can't find a way to determine an absolute window width that would be appropriate for every case. As an aside, however, the two-mic measurement scheme is much less affected with regard to slope.
This is the result of setting all three microphone measurements to 100mm.
The Umik-2 slope now matches the other mics. However, it is still down 1db across the band from 20-60Hz merging about 85Hz. The difference at 10dB originally was about 5dB down, but in setting the window the 10dB value will swing a lot, but this is for a woofer close-mic. Using it for room EQ will something else entirely, but I am not interested in that myself so I haven't experimented with that. It does appear, however, that the window type is far less important for room EQ.
To demonstrate I made a video uploaded to youtube to demonstrate the impact of the impulse window on the SPL response. REW is amazing at the level of detail easily manipulated with real time display of the SPL frequency response.
REW close-mic measurement:
