Using Tidal from HiBy music app
Peterinvan
I was excited to try Tidal from my Hiby Music App (Android on FiiO M11Pro).
I was able to use the excellent Hiby EQ functions playing my Tidal tracks. The Tidal UI is lacking functionality, but EQ is great.
HOWEVER… the link to Tidal seems to time out after I exit the Hiby app. I can’t find a way to re-establish the link to Tidal.
I have had to delete the Hiby app, re-install it, and log into Tidal again.
Any suggestions?
J'ai la version pour téléphone Android où vous pouvez vous inscrire. Cela me permet de me connecter pendant quelques jours, mais il s'est ensuite déconnecté de la marée. Désolé de ne pas pouvoir t'aider. Peut-être que plus tard je le saurai.
I want to try Hiby with Tidal, to bypass any Android processing.
From what I see in Google Play, it was a recent update for Tidal login.
Downloaded last Hiby.
Managed to:
register as a user (easy)
link to my Tidal paid account, non MQA (not easy to find the Hiby option to link to Tidal)
Will follow: test USB cable output to external DAC.
