Using SSD on Bluesound Node Icon
lor-lor
Hello,
I consider buying the Bluesound Node Icon. I would like to plug in a SSD, on which I will store my CD-Collection. Now I don’t know how comfortable you can use the Node ICON as a player for the SSD. I would like to use playlists and I don’t want to use the BlueOS App, but the remote control instead (although I don’t mind to use the App in order to create a playlist, but I don’t want to depend on the App when choosing a playlist).
Now is it possible to have playlists for an external SSD and select them with the remote control after switching on the Node Icon?
Is it easy to access a playlist in the menu, or do I have to go through several settings each time before I can choose one?
Could someone please describe, how many steps I would have to go through each time, when I want to play files from a SSD? (I would like it to be just a few steps, because I compare this to using my CD-Player, where I can just press play and the track-number)
So would the Node Icon be as easy and direct in access as using a CD?
Thanks for your help!
You have 5 buttons on the ICON for presets, these can be linked to playlists. 10 presets are possible with the remote control.
Otherwise nothing works without the app.
This is what the remote control can do:
