Using miniDSP DDRC-24 with 2 pairs of speakers ?
Gunnar78
Hello,
I have a miniDSP DDRC-24 which I currently use for one pair of speakers (no sub).
Does anybody know if I can use the other two outputs to connect a second pair of speakers for alternative use, and do a separate room measuring for them with dirac ? So that I can save the settings for speaker pair 1 (signal only goes out to this 1st speaker-pair with its dirac measurements), AND have the option to change output to the 2nd Speaker pair (saved in a different setting on the minidsp with different dirac settings), thereby switching the used speaker-pair.
Thank you very much for your comment. Would be great to know if that was possible (have no 2nd speaker pair to try as we speak).
Yes you could run two 2.0 systems off a DDRC24 like that. You can have 4 presents and the muting should be stored.
