zicmaveric
- Joined
- Nov 12, 2025
- Messages
- 4
- Likes
- 0
Hi all I have a multi-part question that I can’t find the answer to… hoping you can help!
This is often recommended: to design acoustic treatment panels (if space and budget allow) with a layer of high density material at the front (ex mineral wool) and a layer of lighter material behind it (ex fiberglass). In addition, materials with a density of 150 or more kg/m3 are not recommended because their higher density will reflect more of the sound.
Here are my questions about this:
1- Say I make some thin acoustic panels (due to space restriction) which can make use of a .5" a layer of 150kg/m3 polyester and a 2" layer of 20kg/m3 open-cell foam, what would be the ideal configuration?
2- When you use a higher density material, you typically trap more of the sound. But you also might reflect more of the sound too, compared to a lighter density material. Let’s take for example the combination of 2" 20kg/m3 open-cell foam and the .5" 150kg/m3 polyester… if I place the polyester sheet in the front of the acoustic panel, wouldn’t that make it reflect more of the sound compared to if I put it in the back of the panel (ie behind the light open-cell foam)?
3- When looking at a larger panel made from both mineral wool (32kg/m3) and fiberglass (7kg/m3) why would it be so often recommended to use the high density material in the front and the low density material in the back?
4- Given my goal of making small thin panels and the fact I can’t use the conventional mineral wool and/or fiberglass for this, would you recommend something different than my initial plan of combining polyester sheets (150kg/m3) with open-cell foam (20kg/m3)? Maybes using sheets of Rockwool ComfortBoard 80 (128kg/m3) along with a mass loaded vinyl MLV (24kg/m3) is better than what I was planning?
I would love your input on this! Thanks!
