nonookThanks, true, KSTR and FrenchFan. Both ADC channels see a linear combination of the signal and their own imperfections. This is what the actual cc process sees.
So the signal distortion and the individual ADC distortion can add such that e.g. the digitized data of one ADC channel has the same amplitude but 180deg phase (for a harmonic) compared to that of the other ADC channel. In this case CCA magnitude would give a larger harmonic level and CCA R0+ would discard the negative correlation result and the plot would show - 237dB just like in FrenchFan's measurement.
Net:
Same issue with quantitative harmonic distortion measurement as without CCA when the distortion of ADC is in the same order of magnitude as the distortion of the signal.
Thus CCA helps us on the ADC side regarding noise and nonharmonic spurs, but not with harmonic distortion.
@KSTR , @FrenchFan , did I get it right this time?
I think that's a good summary
For me, with my ADC, I really have a
difference between the 2 channels.
Are the causes well identified,
I don't know.
In any case, the internal distortion correction
of the ADC can lead to phase rotations on H2 and H3
that's for sure.
So for me nothing guarantees the phase between the 2 channels
of the ADC.
For the measurement of the amplitudes of the Harmonics with R0+ I think
that this is not going to be the right method.
Too sensitive to the phase variation between the channels.
