Using a passive volume control hooked to amp output for noise reduction
I got a second hand Wells Audio amp recently and found out that the volume is insanely high as well as the noise floor for it's 6.35mm output. Pretty much unusable whenever the music stops playing.
I am thinking of using a 6.35mm to RCA splitter from the amp output to a passive volume control like a Schiit Sys then back to a 6.35mm female port.
Another method might be using a cheap 6.35mm adaptor with a resistor built in. However I am worried about potential sound quality deterioration as some claim to have on Amazon reviews.
Anyone have prior experiences on the topic? Many thanks:)
Lambda
Why not get a Amp that works properly and has an appropriate amount of gain for your application?
You would also increase output impedance
Doodski
Whew! this thing has power output for headphones au plenty.
Yes, you need to attenuate that output down. Or get different amp.
I'm pretty sure there are XLR attenuating in-line adapters.
Give me awhile to google it. I can't remember the company that sells them.
Doodski
This sort of attenuator is what you want. I am not exactly sure what dB attenuation you need. I don't work in dB for the electronics stuff that I do so you'll need one of the other peeps here to advise you if this is enough attenuation or too much. It has 3 switched positions for 15, 20 or 25 dB reduction. @Lamda is correct in that the output impedance will increase significantly but it will get you up and running if that's all you want.
EDIT: and... your headphone amp has a lot of power so the attenuator needs to be able to handle the power output. This should get you started so you can google more information if need be.
Doodski
The power and voltage output of your amp is too much for the Shure model I linked you to. You need something with bigger internal resisters.
Sharpi31
You can’t attenuate signal between the amp output and headphones using a line level passive preamp - the signal level and impedances are very different from line level audio (eg. signal between DAC and preamp/amp).
You could try to attenuate the signal before the input of your headphone amp - this will work if the problem is excessive headphone amp gain only (in this situation the noise you’re hearing is the noise floor of the source cleanly amplified by the amp). If the headphone amp has a high noise floor (the noise you hear is coming from the amp, not from the source) then you’ll address the gain issue but still have a noise problem.
You could build a high power voltage divider - I haven’t done the sums but I’d guess you’d need 10-20W(?) resistors. Have a look at the circuits used to adapt a loudspeaker amplifier output down to headphone level. This is the only solution I can think of that will do the job between your amp output and headphone, addressing gain and noise (except for transformers, but that gets expensive and harder to calculate - possibly more expensive than buying a new headphone amp that suits your headphones).
JayGilb
West-Central Wisconsin
That mic attenuator is meant to be used with a mono input signal and unless the internal connections are known, I would not use it in this application.
I'm not sure what the problem is ? The headphone amp has a volume control, unless the circuit topography is flawed, why would he be getting such a high level of noise ?
Doodski
Poor ground, poor source signal, noisy amp circuitry. Could be many things. One would need to hear the nasty sound and trace it back with a O-scope. I'm going to stay out of this one. I don't know the pin-outs on the headphone XLR connection nor what the attenuation should be. :facepalm::D I'll just be an observer for this one from here on in.
S
Yeah I might get rid of it considering its very limited usability.
S
I was considering something like this: Amazon link and might give it a try. Would only waste my 10 bucks if it fails lol. I found a 300 ohm HD800 works alright with the noise floor but a 64 ohm Z1R suffered miserably. Might need at least 500 ohm of extra impedance to lower the noise to inaudible level.
S
Yeah and what's horribly designed about this model is the lack of gain control, plus a lack of XLR input. I first encountered huge ground loop noise from RCA cables and later when all devices are plugged into the same strip, the internal noise floor, which is always there even with nothing plugged in.
S
It seems that the gain is set insanely high and nothing short of 200-300 ohms can be used for these. A 64 ohm 100db/mw MDR-Z1R needed like 1 out of 48 steps to reach normal volume and 2 is already pretty loud. I found similar problems with the Schiit Ragnarök 2's 6.35mm output which just can't be used with most mid to lower powered headphones, despite what paid reviews often BS about "Dead silent when no music was played"
