Using a binaural mic set to record one of my speaker builds (finally a decent binaural mic)
RayDunzl
Central Scrutinizer
Riverview FL
Interesting (to me) how the "hiss" noise stops at 4:42.
Thomas_A
Sweden
As mentioned before, I had a question with binaural recordings - what should the ideal headphone response look like? Recording a "room" signature and using a "room" signature headphone a la Harman will add double room signatures.
Joppe Peelen
Joppe Peelen
Den Haag , Netherlands
i do not know, im not all to much in headphones. i believe there is a curve people use to be considered flat for our ears. (the minidsp EARS measurement setup comes with a calibration file for instance) not put much effort in it yet reading up on it
Thomas_A
Sweden
So what is your impression when listening to headphones (which ones)? Is the amount of bass more or less compared to the live event?
Joppe Peelen
Joppe Peelen
naah i do not have a good pair of headphones at the moment (some stupid game headset) i did measure the mics themselfs and compared them to my measuring mic from ISemcon, and bass wise they are rather the same (both being omni's there is propper bass) although, when listened on my headset i think it sounded slightly bass heavy. but that could well be my headphone.
abdo123
Brussels, Belgium
You bought a binaural microphone and you don’t have a decent headphone?
Your priorities don’t seem very straightened up imo.
Thomas_A
Sweden
I would be interested to know how to EQ such files to be compatible with Harman-curve headphones. Especially the bass becomes a bit boomy. I made a try below with EQ but it is still issues.
abdo123
Brussels, Belgium
Good point, the OP has to eq his in-room response to flat for it to sound good on any other end-player device, Other wise you're just compounding treble loss / bass boosts.
Joppe Peelen
Joppe Peelen
i must admit my speakers might have had a slight curve in this direction (since i listen to them in my room) witch, might in the end double the effect your headphones and or speakers add. thus being more bass heavy then they should. Good point!!!
Joppe Peelen
Joppe Peelen
Yeah just using EQ is not enough i think, it still stays a bit to roomy.. the room is troublesome, and even more with a recoding with omni;s :) all the room you can get haha.
i shall try once making the speakers flat, see how that fairs. so the curve is not doubled. the room acoustic might remain troublesome.
Joppe Peelen
Joppe Peelen
Can’t you guys adjust for all this in your head?
Well the problem is not that huge, i did end up with a bit more bass compared to top end since my speakers already had a form of a harman curve. then recorded with a flat mic and then you headphone/speaker added a harman curve again... and we all know all speakers and headphone differ in that regard allot.
i wonder how the Harman curve became a thing. if they did listening tests. the question remains on what speakers where the test music mixed ? did they already had a curve to ? or where they flat. since what i see more often then not in mastered tunes is a abundance of top end, completely countering the curve. then someone can say the preferred the curve, but they could as well leave everything flat on both sides and end up with the same
I might look up how the curve came to be. since its weird to say this is what people prefer, since it is based on how the darn thing was mixed (if at all)
hmm i might have mixed 2 things up, harman headphone curve. and in room speaker curve with reflections.
Rednaxela
NL
Did mine?
Not trying to be argumentative. Maybe I just don’t follow the discussion. In any case I feel there wasn’t much preventing me from experiencing what you were experiencing. Or at least getting an idea.
Joppe Peelen
Joppe Peelen
what a mess :) would be so nice if flat was the way to go in any case. and adjust in the mix for personal taste of the people that create music... its retarded to me to adjust for preferences on the curve of a headphone and in room speakers. instead of reproducing what you put in. in the end its all depending on how a person mixed/mastered it (unless its raw) and what curve if any there speakers/headphones used. what a mess :)
Joppe Peelen
Joppe Peelen
Did mine?
Not trying to be argumentative. Maybe I just don’t follow the discussion. In any case I feel there wasn’t much preventing me from experiencing what you were experiencing. Or at least get an idea.
well i enjoyed the recording when using a headphone (of course in real live its better). maybe a tad to much low end. but yeah. i might make it all to complicated :)
Thomas_A
Sweden
Ideally, you should use headphones calibrated for binaural recordings, in this case for in-concha mics. I’ve seen some posts about it but no curve.
It is of interest since it gives us at least some tools for listening and comparing speakers in rooms.
