Hi,
I've got a Denon receiver without a trigger output, and want to trigger a Buckeye amp and an SVS subwoofer to come on and off with the receiver. So I purchased a TrickleStar power strip and this 12V 500mA DC Power Supply AC Adapter with 3.5 mm plug from PartsExpress. I thought I would plug the receiver into the control outlet and use it to turn that adapter on and off. Since it already has a 3.5mm plug it fits the trigger input. But feeling cautious before plugging it into my gear, I tested the voltage with a multimeter. It reads 18V rather than 12V. I did a bit of Google research and it sounds like this is typical of an unregulated power supply (something I don't know anything about). Apparently it's not uncommon to read a higher voltage with no load. Is an unregulated power supply an issue in this situation? Just trying not to fry my amp and subwoofer.
