- Joined
- Mar 1, 2021
- Messages
- 3,277
- Likes
- 6,925
So you’re using a.i. to fix faults with a.i. ?
Any difference between using human checkers to check the work of humans?So you’re using a.i. to fix faults with a.i. ?
Hi everyone, is there an AI program or something similar that can manipulate images, upscale them to HD (so you can read comments, for example), remove white areas, and fit them into predefined frames? Thanks in advance before I completely lose it.
Thanks for your reply. For example, I create a 25x15 rectangle divided in half and insert images into it. I would also like to increase the resolution of some images to make certain text, which is sometimes a little blurry, easier to read.
Someone should make an AI that teaches humans what is happening inside AI logic.The WeatherNext model seems to be the best currently available predictor for hurricane forecasting. Compared to the previous state of the art it needs less computing power, lower resolution input data, and has similar accuracy at 3 days to the alternative at 2 days which can significantly improve preparation on the ground. The down side is it's a black box, so while it's providing useful results it isn't improving understanding of what the signs it's spotting in the data that we've missed.
https://arstechnica.com/science/2026/08/deepminds-hurricane-model-bought-forecasters-an-extra-day/
There is no logic within an Large Language Model, which is what most people are referring to when they say 'AI' since the advent of ChatGPT.Someone should make an AI that teaches humans what is happening inside AI logic.
In a generic sense, or as in a model that explains its reasoning? Some models have the latter, although they have been known to have faulty explanations for reasons that aren't entirely clear. For the former, unless the model you're trying to explain is instrumented to give you a look inside the black box, another model won't be able to see what's going on any more than people can.Someone should make an AI that teaches humans what is happening inside AI logic.
Tell them you want a badge with your name and title.I recently pitched AI as a facilitator for Test Driven Deployment of (IT) Infrastructure, riffing off Test Driven Development (of software). As a result, i've been nominated to become an 'AI Champion' at my workplace![]()
And a bonus / pay rise!Tell them you want a badge with your name and title.![]()
