Razorhelm
- Joined
- Jan 31, 2020
- Messages
- 169
- Likes
- 337
I think the most interesting thing I have done with AI is make a direct edit to a bios file on my motherboard to enable a feature the manufacturer had not enabled or made visible on the bios menu but the chipset did support. Claude was able to pull a copy of the current bios and patch it to enable the feature in a single pass, it found bios roms from other motherboards with the feature enabled and worked out what they had that mine did not and made the correct edit first time.
This was when i realised how powerful it could be.
I think of it as a new interface to computers and information but different to the computer concepts we are used to. A calculator enhances your maths with perfect precision right inputs in, right outputs out. A LLM is different in a way i can't explain, it has masses of knowledge but it can't reason like we do, it does some form of reasoning but there is a certain ability it's missing, I often think it's like the fast brain in book "Thinking Fast and Slow", it's often right but when something is unusual or counter-intuitive it fails and the failure persists it doesnt have the slow methodical part of the brain to course correct.
I have a home network of multiple machines, I have Claude install programs, tweak code to customise things for me. It has made me a room correction program and i have got it to make what i called an active bass trap and it calls a feedforward modal absorber, which is a subwoofer in a corner playing a signal based on the music I'm playing to reduce the modes and nulls in the room. It's taken a lot of trial and error and I have had to push it hard not to give up but it has worked very well and made something i could not make myself. In audio I can't check it's work, I am not familiar enough with the maths involved in acoustics, however because i can measure the outcome and am familiar with the concepts (mostly from what i have learnt here!) I can challenge it and herd it in the right direction.
However it could do something very wrong and because its a layer of separation from what is being done, I do worry about hidden failures. At one point it forgot it had lowered a speakers level by 30dB and told me the changes made to a filter had no measurable effect, I challenged as it seemed weird to get almost identical results but that's the mistake I caught, I worry about what it's doing that I don't catch.
