I wanted to use Comsol but they are horribly expensive, don't scale well on GPU etc Plus the key value of what i do is to use AI to predict the solution faster than what bem/fem can do and get to control the result with a nightly run. 10 years ago, i would have needed 10 or 20 engineers full time to match my current output and a lot of things would not have been polished the way they are.
100% rust mostly for portability reasons and because the compiler is on the strict side and find bugs generated by xxx agents. Fortran does not provide enough guarantees and I decided to stop f77 25 years ago
I use a python for visualisation or interfacing with other apps.
the value is not in Rust (vs others) it could have been C++ or GO. The value is that is have a 100% coherent codebase that i can compile with 1 command, that works everywhere with almost zero external dependencies. I rebuilt fft, blas, lapack, iterative solvers, etc to be autonomous. It also help the agents to debug the whole stack since I own all the code. Claude and Codex are very knowledgeable in this areas and progressed very quickly.
i had to relearn a lot of my programming skills. in the past i would have re-used as much as possible (use petsc for ex). Now it is unclear how much you benefit from well established solutions. It is clear that they are SOTA for some things but they were written long time ago and are struggling with GPUs for ex. I was surprise by how fast NVIDIA cards are at matrix/vector multiplications.
2d, axy symmetric and 3d
both depending on what i want to do or what the needs has been up to now.
For now i have Euler well tested and Lighthill/FW not that well tested
I dont have proper shock wave support yet (low speed only). I have only done a few academic examples.
Yes I am looking into PINN, currently testing with acoustics for some real time room-eq correction.
One of the magical things with AI is that you can ask: for each kind of physics, find 10 analytical solutions from the litterature for 1d, 2d and 3d (10 for each) and implement them as a QA binary folllowing skills ...
A few hours later you get your 30 binaries that match the analytical solution.
or you can ask, look at arxiv, find me the last 10 papers on 1 physics module (like thermics) with significant impact and where they have reproducible benchmark/results, and again the tool will find them, analyse them write the code and allow you to compare yourself with established solutions. (Semi) Magical.
On the flip side, from time to time, i want to throw the whole thing out of the window, it can regress in a way that was not the case before.
