Used 8341's. Anyone with 83x1's care to help out?
Jsr
About to buy a pair of 8341's but i can't tell if the white ring around the tweeter is normal. Perhaps it's just light and the angle that make it look more pronounced. Can't see them at all on stock pictures while some real pictures of the gray ones have them, albeit not as pronounced. I do plan to inspect and listen to them before purchase.
It's just a dust that's visible, the rings are perfectly okay.
Looks normal to me. They all have a slightly lighter inner ring.
