Use Mini DSP Flex HT with 2x4 HT as active crossover to Biamp?
Pablo1
I have a 5.1 system with Electrostatic towers for the fronts and surrounds that I both have biamped and the speakers have the option to bypass the passive crossovers for use with active crossovers.
For this reason I would like 10 outputs so I can have high and low outputs for those four speakers plus an output for the center and sub. If I connect a 2x4 HD to two of the outputs on the Flex HT then will I still use able to use Dirac Live to configure those two speakers and their hi and low outputs?
I understand this will add an extra AD to DA conversion.
The other option is to run one pair of the speakers biamped with its passive crossover but I am hoping to figure out a solution so both pair of speakers can be biamped with active crossovers.
Any input is appreciated!
