Purpl3n3ss
- Joined
- Jul 26, 2022
- Messages
- 14
- Likes
- 3
Should I use balanced or unbalanced interconnects to an unbalanced integrated amplifier with 6.35mm single-ended headphone output? Both RCA and XLR inputs are provided, though the amplifier is not a balanced design.
The manufacturer says:
"Typically we prefer to use the balanced XLR inputs if using a balanced source. This maintains the benefits of the noise and distortion reduction up until the output of the integrated preamplifier stage."
Is this a technically sound take?
The preamplifier section they mention, uses tubes to convert the balanced signal into unbalanced, in the following way (their words):
"Yes, the two 12AU7s are used in the balanced to single ended conversion. Both triode halves in both tubes are used for a balanced source. Only one half of each for single-ended."
My reason for asking this question is that, switching between balanced XLR and unbalanced RCA interconnects, I'm noticing the RCA interconnects to maybe sound a bit crisper and clearer, contrary to their recommendation. Could it be that this balanced into unbalanced conversion when done inside the amp is doing some damage to the signal, and I'm better off with an unbalanced signal from the DAC itself (via RCA)?
Also, the length of interconnects is very short: 0.5m.
