Sorry if this has been asked before or it's obvious but I'm not sure how this would work.
So PCs can run a lot of DSP with EQ APO or you can just buy Dirac and run it on a PC. So a cheap $200 or less Mini Pc might be the cheapest way to have a lot of DSP at your disposal.
The problem is that I can just use the TV as a normal PC monitor, but If I want to let's say use a Blu-Ray player or the apps in the TV then the PC stops being the source of the sound therefore all DSP would be lost.
Basically what I want is for my PC to take the role of a DAC via HDMI or other port as seen in the first image. Is it possible or should I just use the setup of the second image and try to run all the content via the PC?
PD: I just moved so I don't have a TV to test this out yet I'm just planning out my setup
