USB to COAX/OPTICAL Converter Adapter
inomics
Hello.
I am trying to renew my second audio system, which is a purely digital one (in contrast to the main).
I am looking for a USB to COAX/OPTICAL Converter / Adapter. It should connect a PC laptop with active speakers. Allow volume control in Win-PC or have an own volume controller.
In this thread:
there was the SMSL PO100 Pro suggested.
BTW on amazon it is (wrongly?) advertised as a Digital to Analog Converter:
I have found https://doukaudio.com/collections/d...x-opt-hdmi-converter-digital-interface-dsd256
In terms of features, it looks what I need. Not sure about quality.
Both are made in PRC. I would prefer something quality.
My equipment:
HP ZBook Fury 17 G8 Win 11 with USB-A and and USB-C outputs
USB cable AudioQuest Cinnamon
Roland DS-5 active speakers
Oehlbach NF 113 DI 500 Cinch S/PDIF Coax, 75 Ohm, 5m - to mutually connect Rolands
Thanks for suggestions :)
inomics
Hi @inomics! Welcome to ASR.
A few years ago I bought the basic SMSL PO100 for about 30€, which has performed flawlessly.
SMSL have recently refreshed this model, which is now called PO100 2024.
If I still needed one, that's the one I'd buy.
It has UAC2 Hardware volume control built-in, which means that you can always use the default OS volume slider for volume control, even in macOS and in Windows using ASIO.
I've been using one of these for over four years (mine is not USB-C; newer ones are). No problems.
Thanks staticV3 and gberchin for feedback.
Good to know SMSL and DoukAudio models are reasonably durable.
I am indifferent to USB-A or USB-C.
Update
I received my SMSL Audio PO100. The device works well via both coax and optical.
Thanks for guiding me to this device.
PS For connection to PC, I use Oehlbach Evolution C3 USB. As audio output I use AudioQuest Cinnamon.
Here is one I made a review:
,works totally fine and has a bluetooth on board.
Hello.
In this thread:
My equipment:
inomics
Here is a timecode,I am testing BEA1 usb to optical output:
Hello.
In this thread:
My equipment:
inomics
Am using simpler version of Douk V2 interface for couple of years. Totally problem free. Would recommend it. Quality is fine ... as it is digital to digital interface i just focus on changing sample rates as that can be real-life challenge for some / all problem free, instant and no glitches. Would recommend it highly. Seems 90% of evals on Amazon agree with it: Douk V2
