usb isolator
1: gadget adum 3165
probably better than audioqest jitterbug
2: gadget
ISOUSB211DPEVM board if you use a really good powersupply external the sound will be even better you have to solder it yourself
3: ADUM OCXO-3166 USB
4: JDS Synapse & Neutron V1 USB Isolators Review
so the expensive lhy uip
Galvanic isolator
should give better sound
1: gadget adum 3165
2: gadget
This is a review and detailed measurements of the JDS Labs Synapse and Neutron Hifi V1 USB isolators. They were both sends to me by the respected companies. Synapse costs US $69, and Neutron US $118.
As you see, the styles are very different. Synapse comes in a playful red color. Neutron in a more serious case, resembling a USB power supply.
Some background: USB bus carries data, power and ground. Data is used by all downstream devices naturally (e.g. DACs). Power may or may not be used. The ground however, is always used as the reference for both data and power. Being...
- amirm
- Forum: DACs, Streamers, Servers, Players, Audio Interface
Seriously? Now we're also talking about the crystals?
